sheroy
When compiling for Pi3 in Arch32 enabling VFP
Fri Jul 13, 2018 10:36 pm
I am using arm-none-eabi-gcc (15:5.4.1+svn241155-1) 5.4.1 20160919 to compile.
The instruction FMXR FPEXC, r0 (in my start.s file) gives the following error when compiling to enable VFP.
Error: selected processor does not support `fmxr FPEXC,r0' in ARM mode
my compiler flags are
COPS = -Wall -nostdlib -nostartfiles -ffreestanding -Iinclude -O2 \
-mcpu=cortex-a53 -mfpu=neon -mfloat-abi=hard -mfpu=crypto-neon-fp-armv8
What could be the cause for the error?
Schnoogle
Re: When compiling for Pi3 in Arch32 enabling VFP
Mon Jul 16, 2018 8:47 am
Hi sheroy,
as far as 8 can see you are using the -mfpu directive twice.
I’m also using arm-none-eabi to cross compile my bare metal stuff.
I’m using this settings:
-mfpu=neon-fp-armv8 -mfloat-abi=hard -march=armv8-a
and the compiler does except and compile the fmxr instruction.
BR
Schnoogle
sheroy
Tue Jul 17, 2018 7:24 pm
I tried I get the same error.
Schnoogle
Tue Jul 17, 2018 7:51 pm
well, than the issue might be your -mcpu flag set to cortex-a53 ... I’m not using this one. Instead I do -mtune=cortex-a53 together with -march=armv8-a
Hope this helps.
BR,
Schnoogle
sheroy
Tue Jul 17, 2018 8:19 pm
last time the compiler flags were
It yet gave the same error.
AlfredJingle
Sat Jul 21, 2018 12:23 pm
For what it is worth, I use:
--no-warn -mcpu=cortex-a53+crc -mfpu=neon-vfpv4
which in my case ( I use as, not gcc ) works fine and only reports errors.
going from a 6502 on an Oric-1 to an ARMv8 is quite a big step...
sheroy
Fri Aug 31, 2018 2:37 pm
I have not yet been able to figure out the problem. I have changed my compiler and have started using ARM DS5 to compile and use the makefile with a few modifications.
The compiler is obtained from https://developer.arm.com/open-source/g ... /downloads and linked to the DS5 toolchain.
To refresh the error provided by
arm-none-eabi-gcc -Iinclude -MMD -c src/start32.S -o build/start32_s.o
is
src/start32.S: Assembler messages:
src/start32.S:103: Error: selected processor does not support `vmsr fpexc,r0' in ARM mode
I have not yet been able to enable the floating point unit, I have tried many options (Linux and windows) and have not yet been able to enable the FP unit.
Attached below is a copy of my makefile
ARMGNU ?= arm-none-eabi-
#ARMGNU ?=
         -mcpu=cortex-a53  -mfpu=neon-vfpv4 -mfloat-abi=hard -march=armv8-a+neon+fpv3
#COPS =   -Wall -nostdlib -nostartfiles -ffreestanding -Iinclude -O2  \
#         -mfpu=neon-vfpv4 -mcpu=cortex-a53 -mfloat-abi=hard -march=armv8-a
#old flags
#-mfpu=neon-vfpv4  -mfloat-abi=hard -march=armv7-a  -mtune=cortex-a53
ASMOPS = -Iinclude
BUILD_DIR = build
SRC_DIR = src
all :kernel7.img
clean:
	del  $(BUILD_DIR)\*.o
	del  $(BUILD_DIR)\*.d
#	del  $(BUILD_DIR)\*.elf
$(BUILD_DIR)/%_c.o: $(SRC_DIR)/%.c
#	mkdir -p $(@D)
	$(ARMGNU)gcc $(COPS) -MMD -c $< -o [email protected]
$(BUILD_DIR)/%_s.o: $(SRC_DIR)/%.S
	$(ARMGNU)gcc $(ASMOPS) -MMD -c $< -o [email protected]
C_FILES = $(wildcard src/*.c)
ASM_FILES = $(wildcard src/*.S)
#OBJ_FILES = $(wildcard $(BUILD_DIR)/*.o)
OBJ_FILES = $(C_FILES:$(SRC_DIR)/%.c=$(BUILD_DIR)/%_c.o)
OBJ_FILES += $(ASM_FILES:$(SRC_DIR)/%.S=$(BUILD_DIR)/%_s.o)
DEP_FILES = $(OBJ_FILES:%.o=%.d)
-include $(DEP_FILES)
#include the previously built object files
#OBJ_FILES += $(wildcard $(BUILD_DIR)/*.o)
kernel7.img: $(SRC_DIR)/linker32.ld $(OBJ_FILES)
	$(ARMGNU)ld -T src/linker32.ld  -Map output.map -o $(BUILD_DIR)/kernel7.elf  $(OBJ_FILES)
	$(ARMGNU)objcopy $(BUILD_DIR)/kernel7.elf -O binary kernel7.img
	$(ARMGNU)nm -n  $(BUILD_DIR)/kernel7.elf >  $(BUILD_DIR)/output.symbol
	$(ARMGNU)objdump -D $(BUILD_DIR)/kernel7.elf > $(BUILD_DIR)/output.list
attached is my start.S file extract to enable the FP unit...
@FPU_enable:
@	MRC p15, 0, r0, c1, c1, 2
@	ORR r0, r0, #3<<10
@	MCR p15, 0, r0, c1, c1, 2
@	mrc p15,0,r0,c1,c0, #2			// R0 = Access Control Register
@	orr r0, #(0x300000 + 0xC00000)	// Enable Single & Double Precision
@	mcr p15,0,r0,c1,c0, #2			// Access Control Register = R0
@	mov r0, #0x40000000				// R0 = Enable VFP
	vmsr fpexc,r0					// FPEXC = R0  --- THIS LINE ALWAYS GIVES AN ERROR!!!
if I comment vmsr fpexc,r0 out I am able to compile.
sheroy
[solved] Re: When compiling for Pi3 in Arch32 enabling VFP
Fri Aug 31, 2018 3:39 pm
Sorry fixed it... my assembler options were not being updated
paulwratt
Mon Oct 01, 2018 4:21 am
What does this mean?
Both DietPi and RetroPie MUST build and work on various different machines, including RPi, so if you use their build settings for the 3 different CPU's and it still does not work, the problem is then with your setup.
As alluded to in a previous post, use of "arch=" and "tune=" is preferred over "cpu=". This is the same technique that allows Atari ST gcc builds form v2 to v8 of GCC and its specific BinUtils version.
BTW, does anyone know where to get a pre-compiled archive or package of any gcc-arm-none-eabi for RPi's other than the OS's repo . I use my RPi as everyday systems in a 12v mobile setup, so compiling it myself is out of the question (unless RaspberryPi Foundation ever releases a 2Gb or 4Gb RPi).
Paeryn
Mon Oct 01, 2018 6:12 am
If you look at the Makefile shown the -mcpu and -march options were only applied when compiling C code (using COPTS). For assembly files no -mcpu or -march options were being applied (using ASMOPTS).
Not sure what DietPi and RetroPie have to do with this thread, sheroy hadn't mentioned anything about what they were compiling. Especially as sheroy said a month ago that they had identified the error, was the error was, and that it was now fixed.
paulwratt
Wed Apr 10, 2019 12:04 pm
Nice answer, but you probably should not post delayed (by 4 months) posts like this, but I will clarify:
means @sheroy where is the actual fix, which was the reason for the original post.
I mentioned BOTH DietPi and RetroPi because they both have files that document the actual gcc/make build command lines used. Building them is irrelavant, the fact is they MUST compile on some 20-30 different platforms, without fail, and they do, so if someone has a issue with building a project, then comparing what command line is being used against ones that are know to work is a good place to start.
I just want to know what AS options were being passed, details like that are hard to find as it is mostly done behind the scenes
sheroy
Thu Apr 11, 2019 12:10 pm
The actual fix is:
if you see the make file.. change it to...
ASMOPS = $(INCPATH) $(CPUOPS) $(libs)
It should fix the output initial post...
libs is a new variable... also the answer was posted on Fri Aug 31, 2018 4:39 pm
Edit -- Sorry got confused Thanks for pointing the date out!
Paeryn
Thu Apr 11, 2019 1:30 pm
also the answer was posted on Fri Jun 14, 2013 6:34 pm
Have you been time travelling? That was 5 years before your original post on 13th July 2018. Not counting that the RPi3 wasn't out in 2013 :D
