Schnoogle
I can't get hardware PWM to work on PI3
Wed Jul 11, 2018 11:29 pm
Hi there,
before I loos all my hair ;) I just try to find a possible answer here...
I'm running in baremetal and try to get the hardware PWM running.
I've checked how wiringPI and circle does implement the same and adopt is, but neither a LED nor the Osszi is giving any output on the pins where PWM should be active...
Here is what I did so far:
#define GPIO_ADDRESS 0x00200000 // GPIO base address
#define PWM_ADDRESS  0x0020C000 // PWM settings base address
#define CLK_ADDRESS  0x00101000	// clock management base address
//several Hardware PWM register offset in words
#define PWM_CTL		0x00	// PWM Control
#define PWM_STA		0x01	// PWM Status
#define PWM_DMAC	0x02	// PWM DMA Config
#define PWM_RNG1	0x04	// PWM Channel1 Range
#define PWM_DAT1	0x05	// PWM Channel1 Data
#define PWM_FIF1	0x06	// PWM FIFO input
#define PWM_RNG2	0x08	// PWM Channel2 Range
#define PWM_DAT2	0x09	// PWM Channel2 Data
//the CLK registers
#define CLK_CTLPWM		0x28	// clock control register as word offset refer to: https://de.scribd.com/doc/127599939/BCM2835-Audio-clocks
#define CLK_DIVPWM		0x29    // clock divisor register
#define CLK_PASSWORD (0x5a << 24) // fixed value need to be written to configure the clock manager
#define PWM_RANGE 1024
uint32_t *volatile pwmAddr;
uint32_t *volatile clkAddr;
void test_pwm() {
        pwmAddr = (uint32_t *)(BMC2835_PERI_BASE + PWM_ADDRESS);
        clkAddr = (uint32_t *)(BMC2835_PERI_BASE + CLK_ADDRESS);
	gpio_pin pin1, pin2
	gpio_get_pin(GPIO12, GPIO_ALT0, &pin1); // this just sets the PIN to ALT_FUNC0
	gpio_get_pin(GPIO13, GPIO_ALT0, &pin2); // this just sets the PIN to ALT_FUNC0
	// now setup PWM
	*(pwmAddr+PWM_RNG1) = PWM_RANGE; // default pwm range
	*(pwmAddr+PWM_RNG2) = PWM_RANGE;
	// to setup PWM first disable to be able to change the clock
	*(pwmAddr+PWM_CTL) = 0; // stop PWM
	*(clkAddr+CLK_CTLPWM) = CLK_PASSWORD | 0x1 << 5; // STOP pwm clock
	t_usleep(110);
	// wait for the clock not being busy any longer
	while ( (*(clkAddr+CLK_CTLPWM) & 0x80) != 0) {
		t_usleep(1);
	//set the divisor of the clock
	uint32_t divisor = 2;
	*(clkAddr+CLK_DIVPWM) = CLK_PASSWORD | (divisor << 12);
	*(clkAddr+CLK_CTLPWM) = CLK_PASSWORD |0x1; // set clock source
	t_usleep(10);
	*(clkAddr+CLK_CTLPWM) = *(clkAddr+CLK_CTLPWM) | CLK_PASSWORD | 0x1 << 4; // enable clock
	*(pwmAddr+PWM_CTL) = 1 << 0 | 1 << 8; // enable both PWM channels in PWM mode
	// now write data to PWM
	uint32_t value = 256;
	*(pwmAddr+PWM_DAT1) = PWM_RANGE - value;
	*(pwmAddr+PWM_DAT2) = value;
	while(1);
As the PWM is running in "standard" mode I would have expected the _-_-_- on my osszi on one of the GPIO pins or a LED being more lit on the one than the other PWM pin....
I can't find that I'm doing something obviously wrong or I just missed one ore even several additional "activation" flags that need to be set ...
From the register content the PWM clock is running (the enabled and the busy bits are set)
Any hint would be much appreciated....
BR
Schnoogle
bzt
Re: I can't get hardware PWM to work on PI3
Sun Jul 29, 2018 10:27 am
I'm sorry I don't know the answer to your question, but since you haven't got any answers yet, I suppose a guess is better than nothing.
Having a busy flag set in a pheriperal usually means further operations are blocked. Read the BCM doc looking for how to acknowledge a PWM clock tick and clear the busy flag. Again, just a guess. I haven't used PWM clock. I use PWM only to reset and shutdown the board.
Cheers,
bzt
Schnoogle
Wed Aug 01, 2018 6:32 pm
Hi bzt,
thanks for trying to help me out with this issue. From the documents I've seen so far for the RPi clocks, the busy flag mean, that the clock is running and creates clock cycles based on the current setting. To change the settings you need to stop the clock, wait until the busy flag is clear (this is what my code is doing) and after changing the settings the clock should be activated and the busy flag should be set to indicate the clock is running... However, I've also tried to use the code as in the pigpio library that could be found here: https://github.com/joan2937/pigpio but unfortunately this also does not seem to work on m baremetal Pi :/
I might start implementing some basic software PWM to control my motor's but as this is eating up a whole core to run it in parallel I would rather like to get the pulses created right away from the hardware :)
Thanks again.
BR,
Schnoogle
elahav
Fri Jan 18, 2019 11:24 am
I was running into similar problems when trying to enable hardware PWM. Unfortunately all the examples use existing libraries, which doesn't tell you how to bang the bits directly to get PWM going. The following example is derived from reading https://www.scribd.com/doc/127599939/BC ... dio-clocks and the WiringPi code. It is targeting a QNX system, but you should be able to adapt it to a bare metal environment or to other operating systems. The two functions you will need to adapt are mmap() (not required if the MMU is not enabled in a bare-metal environment) and nanospin_ns() (replace with whatever delay mechanism you have).
I avoided symbolic constants on purpose, in order to show clearly the values that need to be written to the different registers.
#include <stdio.h>
#include <unistd.h>
#include <time.h>
#include <stdlib.h>
#include <stdint.h>
#include <sys/mman.h>
static uint32_t volatile	*gpio_regs;
static uint32_t volatile	*pwm_regs;
static uint32_t volatile	*clk_regs;
int
main(int argc, char **argv)
	unsigned	duty = 512;
	if (argc > 1) {
		// Get a duty cycle value from 0 to 1024 from the command line.
		duty = strtoul(argv[1], NULL, 0);
		if (duty > 1024) {
			duty = 1024;
	// Map the GPIO registers.
	gpio_regs = mmap(0, __PAGESIZE,
					 PROT_READ | PROT_WRITE | PROT_NOCACHE,
					 MAP_SHARED | MAP_PHYS,
					 -1, 0x3f200000);
	if (gpio_regs == MAP_FAILED) {
		perror("mmap");
		return 1;
	// Map the PWM registers.
	pwm_regs = mmap(0, __PAGESIZE,
					 -1, 0x3f20c000);
	if (pwm_regs == MAP_FAILED) {
		perror("mmap");
		return 1;
	// Map the clock registers.
	clk_regs = mmap(0, __PAGESIZE,
					 -1, 0x3f101000);
	if (clk_regs == MAP_FAILED) {
		perror("mmap");
		return 1;
	// FSEL18=2 => GPIO 18 uses ALT5, which is PWM0.
	gpio_regs[1] &= ~(7 << 24);
	gpio_regs[1] |= (2 << 24);
	nanospin_ns(100000);
	unsigned	freq = 1000;
	unsigned	range = 1024;
	unsigned	div = 19200000 / (freq * range);
	printf("duty=%u div=%u\n", duty, div);
	// Stop PWM.
	pwm_regs[0] = 0;
	// Stop clock.
	clk_regs[40] = 0x5A000001;
	// A comment in WiringPi says that a delay of ~100us is required after the
	// clock is disabled, though I don't see why given the loop below.
	// Wait for the clock to become idle.
	while (clk_regs[40] & 0x80) {
		nanospin_ns(1000);
	// Write a new divisor and restart clock.
	clk_regs[41] = 0x5A000000 | (div << 12);
	clk_regs[40] = 0x5A000011;
	// Set channel 1 range.
	pwm_regs[4] = range;
	// Enable PWM channel 1 in PWM mode.
	pwm_regs[0] = 1;
	// Set the duty cycle on channel 1.
	pwm_regs[5] = duty;
	for (;;) {
		printf("clk=%.8x pwm=%.8x range=%.8x\n", clk_regs[41], pwm_regs[0],
			   pwm_regs[4]);
		sleep(1);
	return 0;
