Page 2 of 2
Re: Use a FT232H-Chip to debug Pi 1 B+ via JTag + OpenOCD config
Posted: Mon Apr 16, 2018 6:20 pm
by SonicWave
So "halt" does work, but "step" doesn't:
[email protected]:~/Desktop/openocd$ openocd -f custom_configs/ft232h.cfg -f custom_configs/raspi.cfg
Open On-Chip Debugger 0.10.0+dev-00391-gf00d9bb1 (2018-04-09-20:32)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.org/doc/doxygen/bugs.html
adapter speed: 1000 kHz
none separate
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
raspi.arm
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 1000 kHz
Info : JTAG tap: raspi.arm tap/device found: 0x07b7617f (mfg: 0x0bf (Broadcom), part: 0x7b76, ver: 0x0)
Info : found ARM1176
Info : raspi.arm: hardware has 6 breakpoints, 2 watchpoints
Warn : Scan chain 7 shifted out unexpected address
Info : Listening on port 3333 for gdb connections
Info : accepting 'telnet' connection on tcp/4444
target halted in ARM state due to debug-request, current mode: Undefined instruction
cpsr: 0x800001db pc: 0x00008014
Error: wDTR/rDTR inconsistent (DSCR 40006103)
[email protected]:~/Desktop/raspberrypi/armjtag$ telnet localhost 4444
Trying ::1...
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
> halt
> step
I searched google for a while and found articles back from 2008. It looks like the same problem (halt is possible but step isn't, "Scan chain shifted out of unexpected address" - messages) occured several times in that year. But I guess they should have fixed it by now, especially because it works fine at your configuration, dwelch67.
It is quite disappointing that something which should work, doesn't work :(
So just to clarify: You are using a FT232H and not an FT2232h, right?
Posted: Thu Apr 19, 2018 12:32 am
by dwelch67
Yep, FT232H most recently. Have used FT2232h have used FT4232h, jlink, all work just fine.
Posted: Sat Apr 21, 2018 9:59 am
by SonicWave
Is it possible to use a ST-Link V2, which is capable of JTAG, instead of a FT232H? I used the stlink.cfg of openocd with this command:
[email protected]:~/Desktop/openocd$ openocd -f tcl/interface/stlink.cfg -f custom_configs/raspi.cfg
none separate
custom_configs/raspi.cfg:26: Error: invalid subcommand "newtap raspi arm -irlen 5 -expected-id 0x07b7617F"
in procedure 'script'
at file "embedded:startup.tcl", line 60
in procedure 'jtag' called at file "custom_configs/raspi.cfg", line 26
with:
raspi.cfg
# Broadcom 2835 on Raspberry Pi
telnet_port 4444
adapter_khz 1000
if { [info exists CHIPNAME] } {
set _CHIPNAME $CHIPNAME
} else {
set _CHIPNAME raspi
reset_config none
if { [info exists CPU_TAPID ] } {
set _CPU_TAPID $CPU_TAPID
} else {
set _CPU_TAPID 0x07b7617F
jtag newtap $_CHIPNAME arm -irlen 5 -expected-id $_CPU_TAPID
set _TARGETNAME $_CHIPNAME.arm
target create $_TARGETNAME arm11 -chain-position $_TARGETNAME
stlink.cfg
interface hla
transport select hla_jtag
hla_layout stlink
hla_device_desc "ST-LINK"
hla_vid_pid 0x0483 0x3744 0x0483 0x3748 0x0483 0x374b
Any ideas?
Posted: Sun Apr 22, 2018 12:44 am
by dwelch67
St-link is a two wire SWD, a sort of jtag transport, or basically not JTAG. Dont see how this could possibly work, you dont have the right signals.
Posted: Sun Apr 22, 2018 12:58 am
by dwelch67
Reading back...I have no use for step so never tried (well it is been many many years). halt, load_image, resume, mdw, mww are basically all I need/use. With microcontrollers I use the flash commands if supported.
To get as far as you have gotten the jtag is working just fine, new hardware shouldnt change anything, a zillion bits have gone by just to get to that point. Would look into the software side of it. openocd is open source and ARM has documented the interface, you can look and see what is going on.
perhaps come in through gdb? or is gdb how you got there, try it without gdb, use the telnet interface instead.
David
Posted: Sun Apr 22, 2018 12:59 am
by dwelch67
Are you not able to halt, load a program, and resume?
Posted: Sun Apr 22, 2018 7:24 am
by SonicWave
It's the same error as I posted above.
Halt is possible, but uploading and resuming not.
I guess I will stick with the SD-card method then, I am tired of openOCD. Thanks for all the help though.
Posted: Sun Apr 22, 2018 11:57 pm
by dwelch67
Why not use the ftdi board as a uart to access a bootloader? No reason to remove the sd card more than one more time. Only two wires to hook up rather than 5 or 6. No reason to do the sd card dance if you cant get jtag to work.
