I've been struggling with getting serial comms working for a couple of days and so far has not come up with an explanation of the behaviour I'm seeing. I'm hoping someone has a suggestion which can explain the behaviour and also reliably fix it.
I can get my serial transmit and receive code to work if its the first thing I do in my main routine - so there's nothing essentially wrong with the code or the hardware.
However if I put the serial initialisation code after my console init code which sets up the screen and prints an initial line, serial transmit works, but read never receives a character.
If I remove the "printf" from the console init code, i.e. just allocate the framebuffer and clear it, then serial receive works.
If I insert a particular "printf" in the serial init code between setting the registers and setting the GPIO pin functions, serial receive works regardless of when the init code is called.
I'm guessing this has something to do with memory barriers, although an initial attempt to use one made no difference, using the following code:
int name = 0;
__asm__ __volatile__ ("mcr p15,0,%[t],c7,c10,4\n" :: [t] "r" (name) : "memory");
Is this likely to be a memory barrier issue? I'm totally bemused as to why the presence or absence of a printf would prevent receive from working (while transmit always works).
