btauro
Raspberry Pi 3 Kernel Development with Broadcom 2835
Mon Jan 15, 2018 7:32 am
I have started my long journey in RISC Os development in Raspberry Pi3 with a ambitious goal to have a decent minimal kernel up and running within 3 months .
As there is insufficient documentation from broad-com i would like to know whether apart from LED pin shift ,Multi Cores, Memory Base Address could i use broad-com 2835 documentation to build a kernel in raspberry pi3 for BCM 2837.
Re: Raspberry Pi 3 Kernel Development with Broadcom 2835
Mon Jan 15, 2018 9:58 am
The main difference in the CPU's is the ARM cores - which are documented by ARM themselves - the rest of the documentation for the 2835 (The GPU stuff) should be applicable to all models.
dwelch67
Mon Jan 15, 2018 2:07 pm
Note the sticky topics have lots of good links, somewhere in there you will find a community based errata for the broadcom documentation, bugs in the docs that folks have found and bothered to document. No need to re-hack the same wheel.
