zedrummer
Practical question: RPi SD card reader worn
Mon Jan 08, 2018 9:16 am
Hello
I was wondering, as bare metal programming is about changing the kernel.img file of the SD card, replacing it on the RPi, testing, removing it, changing the kernel.img..., if there are no risks for the RPi SD card reader to get worn (even if I remove and replace the card carefully)?
Thank you
Cathy L.
Re: Practical question: RPi SD card reader worn
Mon Jan 08, 2018 10:15 am
The socket is good for tens of thousands of pull/push operations.
The microSD is good for hundreds of thousands of re-write operations.
So you shouldn't have a problem.
Just check you're not getting dust and cruft in the SDCard slot.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
zedrummer
Mon Jan 08, 2018 10:18 am
Thank you for your quick answer Dougie. I'll take care about the dust.
Cathy L.
bzt
Mon Jan 08, 2018 1:10 pm
Hi Cathy!
If you are worrying about it, you can use this: https://github.com/mrvn/raspbootin
It will use a fix kernel.img on the SD card which will load your real kernel.img over serial. No need to remove the SD card at all.
Bests,
bzt
zedrummer
Mon Jan 08, 2018 3:25 pm
That seems an easy and nice bootloader to help debugging.
Thanks a lot bzt
dwelch67
Mon Jan 08, 2018 3:50 pm
I agree, go with a bootloader. the original pi something about that full sized slot would crack a corner of my sd card adapters, ran through a number of them (before having a solid bootloader). later adafruit made a pcb flush mount micro sd adapter that would slide in and that problem got solved.
Return to “Bare metal, Assembly language”
