sameh4
Problem connecting Rpi Zero as I2C master to Arduino Uno as I2C slave
Fri Dec 22, 2017 2:08 pm
I am not very familiar with Arduino, but I do have one Uno board and one Mega board (don't as me why :) ). I am able to get the Mega to talk to the Uno with the following the code in this link https://forum.arduino.cc/index.php?topi ... #msg776392
The value of x gets incremented and printed in the Arduino IDE's serial monitor. So far so good.
When I try to do the same from the Pi to the Uno, it seems there's no communication being made. I added some debugging as you'll see..
Please forgive the Pi code below, it's just a test as a proof of concept and needs a lot of work of course:
// I am using GPIO pins 2 and 3 for SDA and SCL respectively
// Those are physical pins 3 & 5 of the 40 pins
#define GPIO_BASE  0x20200000
#define BSC1_BASE  0x20804000
#define GPFSEL0  (*(volatile u32 *)(GPIO_BASE + 0x0))
#define BSC1_C  (*(volatile u32 *)(BSC1_BASE + 0x00))
#define BSC1_S  (*(volatile u32 *)(BSC1_BASE + 0x01))
#define BSC1_DLEN  (*(volatile u32 *)(BSC1_BASE + 0x02))
#define BSC1_A  (*(volatile u32 *)(BSC1_BASE + 0x03))
#define BSC1_FIFO  (*(volatile u32 *)(BSC1_BASE + 0x04))
/** CONTROL REGISTER **/
#define BSC_C_I2CEN  (1 << 15)
#define BSC_C_ST  (1 << 7)
#define BSC_C_CLEAR  (1 << 4)
#define BSC_C_READ  1
// ENABLE I2C,
//START TRANSFER
#define START_WRITE  BSC_C_I2CEN | BSC_C_ST
/** STATUS REGISTER **/
#define BSC_S_CLKT  (1 << 9)
#define BSC_S_ERR  (1 << 8)
#define BSC_S_DONE  (1 << 1)
// CLEAR "CLOCK TIMEOUT",
// CLEAR "Uno HAS NOT ACK ITS ADDRESS",
//CLEAR "TRANSFER DONE"
#define CLEAR_STATUS  BSC_S_CLKT | BSC_S_ERR | BSC_S_DONE
MiniUART uart;
u8 x = 0;
void sleep(u8 count) {
    while (--count){
        for(u32 ra=0;ra<0x10000;ra++)
            continue;
void i2c_test() {
    // clear the function select
    // for pin 2 and 3
    GPFSEL0 &= ~(7 << 2*3);
    GPFSEL0 &= ~(7 << 3*3);
    // setup pin 2 and pin 3 as ALT 0
    GPFSEL0 |= (1 << 8);
    GPFSEL0 |= (1 << 11);
    u8 msg[] = "Init I2C Communication\r";
    uart.send(msg);
    // Uno address, set by Uno
    BSC1_A = 0x4;
    u8 msg1[] = "Start with a write\r";
    uart.send(msg1);
    BSC1_DLEN = 5;           // five bytes
    BSC1_FIFO = x;           // value incremented
    BSC1_S = CLEAR_STATUS;
    BSC1_C = START_WRITE;
    check_uno_ack_error();
    check_uno_clock_stretch_error();
    u8 msg2[] = "wait for i2c done\r";
    uart.send(msg2);
    wait_i2c_done();
    sleep(10);
    x++;
// Function to wait for the I2C transaction to complete
void wait_i2c_done() {
    int timeout = 10;
    bool error = (!((BSC1_S) & BSC_S_DONE));
    while( error && --timeout) {
        error = (!((BSC1_S) & BSC_S_CLKT));
        u8 msg[] = "Uno has not yet read.\r";
        uart.send(msg);
        sleep(10);
    if (timeout == 0 ) {
        u8 msg[] = "Timeout while waiting for Uno to read, let's start over.\r";
        uart.send(msg);
void check_uno_ack_error() {
    int timeout = 10;
    bool error = (!((BSC1_S) & BSC_S_ERR));
        u8 msg[] = "Uno has not ACK its address.\r";
        uart.send(msg);
        sleep(10);
void check_uno_clock_stretch_error() {
    int timeout = 10;
    bool error = (!((BSC1_S) & BSC_S_CLKT));
        u8 msg[] = "Clock Stretch Error.\r";
        uart.send(msg);
        sleep(10);
UART is used for debugging as you can see, and it prints the following, over and over:
Start with a write
... x10
... x10
wait for i2c done
... x10
The i2c_test is of course being called from kernel_main in an endless loop.
Any thoughts on why it's not woking?
AlfredJingle
Re: Problem connecting Rpi Zero as I2C master to Arduino Uno as I2C slave
Sat Jan 06, 2018 3:54 pm
The Raspberries (all versions) have a hardware-bug in the i2c controllers. The bug being that the rPi cannot correctly handle clock-stretching. See for instance: http://elinux.org/BCM2835_datasheet_err ... stretching. Your problem looks very much like that bug. There is no work-around OTHER than trying to run the i2c at a lower frequency. Even trying frequencies way below 100 kHz can be tried ( It would be so nice if the bug was repaired in the next version of the raspberry. Please, please, please Gert!)
going from a 6502 on an Oric-1 to an ARMv8 is quite a big step...
asandford
Sun Jan 07, 2018 1:23 am
How are you connecting the Pi to the Uno?
