inaciose
Anyone can compile the LdB sample on linux?
Wed Oct 04, 2017 3:03 pm
Anyone can compile the LdB sample on a Rasperry Pi 2/3 ?
https://github.com/LdB-ECM/Raspberry-Pi ... m32_64_USB
Bellow its a description of what I have done and fails with arm-none-eabi-ld: cannot find libc.a.
I have done a Makefile and change the rpi-smartstart.h to rpi-SmartStart.h, and the respective includes (the windows its case insensitive), removed the assert entries from code.
The gcc version
arm-none-eabi-gcc --version
arm-none-eabi-gcc (4.8.4-1+11-1) 4.8.4 20141219 (release)
The error:
Makefile:35: recipe for target 'kernel.bin' failed
The line with the error is:
arm-none-eabi-ld SmartStart32.o rpi-SmartStart.o emb-stdio.o Main.o -L /usr/lib/gcc/arm-none-eabi/4.8/libgcc.a /usr/lib/gcc/arm-none-eabi/4.8/../../../arm-none-eabi/lib/libc.a /usr/lib/gcc/arm-none-eabi/4.8/../../../arm-none-eabi/lib/libm.a -T rpi32.ld -o kernel.elf
The library file paths translate to (and files exists):
ls /usr/lib/arm-none-eabi/lib/libc.a
ls /usr/lib/arm-none-eabi/lib/libm.a
The Makefile
ARMGNU ?= arm-none-eabi
COPS = -Wall -O2 -nostdlib -nostartfiles -ffreestanding -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -mno-unaligned-access -fno-exceptions -I. -std=c99
LIBGCC = $(shell $(ARMGNU)-gcc -print-libgcc-file-name)
LIBC = $(shell $(ARMGNU)-gcc -print-file-name=libc.a)
LIBM = $(shell $(ARMGNU)-gcc -print-file-name=libm.a)
LIBS = $(LIBGCC) $(LIBC) $(LIBM)
all : kernel.bin
clean :
        rm -f *.o
        rm -f *.bin
        rm -f *.hex
        rm -f *.elf
        rm -f *.list
        rm -f *.img
SmartStart32.o : SmartStart32.S
        #(ARMGNU)-as SmartStart32.S -o SmartStart32.o
        $(ARMGNU)-gcc $(COPS) -c SmartStart32.S -o SmartStart32.o
rpi-SmartStart.o : rpi-SmartStart.c
        $(ARMGNU)-gcc $(COPS) -c rpi-SmartStart.c -o rpi-SmartStart.o
emb-stdio.o : emb-stdio.c
        $(ARMGNU)-gcc $(COPS) -c emb-stdio.c -o emb-stdio.o
Main.o : Main.c
        $(ARMGNU)-gcc $(COPS) -c Main.c -o Main.o
kernel.bin : rpi32.ld SmartStart32.o rpi-SmartStart.o emb-stdio.o Main.o
        $(ARMGNU)-ld SmartStart32.o rpi-SmartStart.o emb-stdio.o Main.o $(LIBS) -T rpi32.ld -o kernel.elf
        $(ARMGNU)-objdump -D kernel.elf > kernel.list
LdB
Re: Anyone can compile the LdB sample on linux?
Sun Oct 08, 2017 5:56 am
The asserts would have been find you just needed to tell it to use C11 with the flag
std=C11 rather than std=c99 you used
static compile time asserts were added as C standard in C11.
C11 was almost complete from the GCC 4.8 status listing
http://gcc.gnu.org/gcc-4.8/cxx0x_status.html
The problem will old GCC 4.8 will be the I have provided printf (in emb-stdio.c) which will get hung up with the actual system printf.
I can suggest 2 quick solutions depending if you know how to retarget the compiler
1. Replace all references to emb-stdio.c for the proper c standard stdio.c and retarget the compiler
emb-stdio is my version of stdio but it is 64 bit retargettable.
2. Follow my instructions to add 6.3 C compiler alongside you 4.8 on the Pi
https://github.com/LdB-ECM/Docs_and_Ima ... 6_On_Pi.md
As per above retargetting the old 4.8 compiler way won't work on AARCH64 which is why I didn't do it that way.
If I get time tonight I will retarget on the old 4.8 for you.
jahboater
Sun Oct 08, 2017 8:34 am
On that latest Raspbian (stretch) the default installed compiler is GCC 6.3.
and the default C language standard for 6.3 is now -std=gnu11 (C11).
LdB
Sun Oct 08, 2017 8:56 am
Nice I was just doing Raspbian 4.8 and it has the stupid bug for initializers
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=53119
You have to work out how many braces to put around each { 0}, {{0}}, {{{0}}},{{{{0}}}} ... fun fun
Array bound warning bug as well
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=59124
So you can't run -O3 optimization you have to drop to -O2 on it
An example of reasons to not use real old GCC compilers :-)
Update: Now I got to a problem which needs someone familiar with linux to explain.
Here is my bash script
#!/bin/sh
gcc -Wall -O2 -std=c11 -mfpu=neon-vfpv4 -mfloat-abi=hard -march=armv8-a -mtune=cortex-a53 -mno-unaligned-access -nostdlib -nostartfiles -ffreestanding -fno-asynchronous-unwind-tables -fomit-frame-pointer -Wa,-a>list.txt -Wl,-gc-sections -Wl,--build-id=none -Wl,-Bdynamic -Wl,-Map,kernel.map -Wl,-T,rpi32.ld Main.c SmartStart32.S rpi-SmartStart.c emb-stdio.c rpi-USB.c -o kernel.elf -lc -lm -lgcc
objcopy kernel.elf -O binary DiskImg/kernel8-32.img
So it's two lines after the shebang .. now the weird bit
If I cut and paste the lines individually they work. If I run the script the last library instruction fails which as shown is -lgcc but if I reorder so -lc or -lm is last it will be that one that fails. I am wonder if I have a Carriage Return causing a problem since I made it in windows.
I am obviously failing at bash script 101 :-(
Sun Oct 08, 2017 9:46 am
Where are you stating the input/source file in that line? The last argument to gcc should be the name of the source file.
[edit] Ah, found them. Hidden in the middle.
Try putting the "Main.c SmartStart32.S rpi-SmartStart.c emb-stdio.c rpi-USB.c" bits after all the other entries.
LdB
Sun Oct 08, 2017 9:48 am
Doesn't have to be first it knows the flags all start with "-" sign, it's Main.c scroll across
As I said line works perfectly if I cut and paste .. I am thinking I have a CR from windows. Trying to work out how to remove any CR :-).
Will shuffle them to start but it's compiling just has trouble with linker on last name in list .. which is why I suspect CR issue.
Update: Yep was the CR .. installed fromdos
sudo apt-get install tofrodos
Then ran fromdos on file fixed it up.
Will now add the new stuff to it and upload a new copy with bash scripts :-)
Who is online
Users browsing this forum: No registered users and 6 guests
