AALLeeXXX
gcc options for virtualisation ?
Wed Aug 30, 2017 1:56 pm
Hello everybody,
I'm trying to embed a HVC instruction in my C source directly, with a statement asm ("hvc"); but gcc reports the following error:
arm-none-eabi-gcc -c -O0 -mfpu=neon-vfpv4 -mfloat-abi=hard -march=armv7-a -mtune=cortex-a7 -g -nostartfiles -Wa,-acdghln=obj/pishell.lst -DRPI2 -o obj/pishell.o src/pishell.c
/tmp/ccY0ON4h.s: Assembler messages:
/tmp/ccY0ON4h.s:1359: Error: selected processor does not support ARM mode `hvc'
make: *** [obj/pishell.o] Error 1
make: Target 'image' not remade because of errors.
Options I selected should match my PI2 I think, but seems virtualisation is not considered. In gcc documentation I could not find any dedicated option for virtualisation or hypervisor. I'm sure I missed something but still could not find it.
In assembler I perfectly can use this instruction, with following options:
AOPS = --warn --fatal-warnings
obj/start_$(SRC).o: src/$(ASMLIST)
	echo Building assembler file
	echo TCPREFIX = $(TCPREFIX)
	$(TCPREFIX)-as $(AOPS) $^ -o $@ -acdghln=$(basename $@).lst
Nothing processor specific.
I alreeady noticed previously ERET was not supported if I enabled for the assembler processor specific options, like above for gcc:
AOPS = --warn --fatal-warnings -march=armv7-a
Seems virtualisation features require a special options set ?
Thanks in advance for any hints.
ALeX
LdB
Re: gcc options for virtualisation ?
Wed Aug 30, 2017 2:53 pm
I have only done it on ARM8 and it's supported there.
I have however seen a weird macro in lots of places
https://github.com/u-boot/u-boot/blob/m ... des-virt.h
#define __HVC(imm16) __inst_arm_thumb32( \
0xE1400070 | (((imm16) & 0xFFF0) << 4) | ((imm16) & 0x000F), \
0xF7E08000 | (((imm16) & 0xF000) << 4) | ((imm16) & 0x0FFF) \
I think you may have just answered why :-)
Paeryn
Wed Aug 30, 2017 2:56 pm
They are available, you haven't told gcc the correct architecture, it's -march=armv7ve (armv7-a with virtualisation extensions). I don't think it's an official architecture name but since an implementation of armv7-a doesn't have to support the virtualisation extensions gcc uses it to stop you compiling code for processors that don't support it.
You could have, instead of using -march and -mtune, just used -mcpu=cortex-a7 that will set the architecture to the correct value for the cpu as well as setting the tuning.
AALLeeXXX
Fri Sep 01, 2017 2:07 pm
Hello Thanks for the reply.
Well, indeed in the tools chain I was using, a pretty old one (gcc-arm-none-eabi-4_7-2013q3) the armv7ve was not available.
Then I changed to a recent toolchain gcc-arm-none-eabi-6-2017-q2-update... but I don't get any better result with either one or other options set:
arm-none-eabi-gcc -c -O0 -mfpu=neon-vfpv4 -mfloat-abi=hard -mcpu=cortex-a7 -g -nostartfiles -Wa,-acdghln=obj/pishell.lst -DRPI2 -o obj/pishell.o src/pishell.c
/tmp/ccszoern.s: Assembler messages:
/tmp/ccszoern.s:1397: Error: missing expression -- `hvc'
Makefile:52: recipe for target 'obj/pishell.o' failed
Or
arm-none-eabi-gcc -c -O0 -mfpu=neon-vfpv4 -mfloat-abi=hard -march=armv7ve -mtune=cortex-a7 -g -nostartfiles -Wa,-acdghln=obj/pishell.lst -DRPI2 -o obj/pishell.o src/pishell.c
/tmp/cccHL8L9.s: Assembler messages:
/tmp/cccHL8L9.s:1401: Error: missing expression -- `hvc'
Am I still missing something here ?
AALLeeXXX
Fri Sep 01, 2017 2:17 pm
Wooo, indeed !!
Seems however this code is pretty ld now, 2012... maybe gcc did not support virtualisation instructions ?
But they made it anyway ;-)
LdB
Fri Sep 01, 2017 2:40 pm
I am on 6.3 Official ARM GCC with settings
-mfpu=neon -mfloat-abi=hard -march=armv7ve -mtune=cortex-a7
and this works just fine
hvc #0
I get your error if I forget to put some immediate value after it like
hvc
results in
SmartStart32.S:85: Error: missing expression -- `hvc'
AALLeeXXX
Fri Sep 01, 2017 3:24 pm
Oh, ok, confirmed !
Works fine with the immediate value as argument, I though it was optional.
Thanks !!
Return to “Bare metal”
Who is online
Users browsing this forum: No registered users and 6 guests
