colinh
ARM integer v. NEON/VFP float instruction timings
Tue Aug 22, 2017 4:35 pm
A. How do the instruction timings (number of clock cycles) compare for the following instructions:
add   r0, r1, r2
vadd.s32  q0, q1, q2         // vector integer
vadd.f32  q0, q1, q2         // vector floating point
vadd.s32  s0, s1, s2         // scalar integer
vadd.f32  s0, s1, s2         // scalar floating point
mul   r0, r1, r2
vmul.s32  q0, q1, q2
vmul.f32  q0, q1, q2
vmul.s32  s0, s1, s2
vmul.f32  s0, s1, s2
B. Are the clock rates the same for ARM core and the NEON unit?
C. multiply instructions take several cycles. Do they stall the pipeline, or does the next instruction execute in the next cycle, as long as the result register of the multiply is not used?
ldm  r0, {r1-r8}
add  r9, r10, r11   // executes with the ldm instruction carrying on in the background
mul  r0, r1, r2
add  r3, r4, r5               // what about this?
vmul.f32  q0, q1, q2
vadd.f32  q3, q4, q5          // or this?
vmul.f32  q0, q1, q2
add  r3, r4, r5               // or even this?
jahboater
Re: ARM integer v. NEON/VFP float instruction timings
Tue Aug 22, 2017 4:57 pm
NEON on ARMv8 is no longer a co-processor which may make a difference.
And ARMv8 NEON is quad issue - which should make a big difference.
So I believe NEON is very fast, but I have no idea about actual timings*
The Pi3 and the new Pi2 are ARMv8.
* Though not answering your questions, the only benchmarking I did was moving and setting large amounts of memory using NEON instead of memcpy/memset, and NEON was around 8-10x faster.
Gavinmc42
Thu Aug 24, 2017 4:24 am
I'm dancing on Rainbows.
LdB
Thu Aug 24, 2017 6:09 am
There is a couple of bugs or changes to the firmware that have occurred since Peters code, I don't know which.
I picked them up when I baremetalled the hello_fft sample on the Pi repo and it disagreed with some of the things Peters code does.
