johnjones
Fast boot (sub second) of pi zero w - howto ?
Sat Jun 17, 2017 6:55 am
Hi
I am working on a project for a charity and would like to use a pi zero w, However the project needs the device to capture a image in 1-2 seconds from power on.
Please would you post details if you have achieved an linux environment with the pi zero w ( BCM2835 ).
I realise that the default firmware config would not allow this. has anyone had any success with sub second boot ?
(I find it hard to believe the videocore designers did not envisage a device to turn on and be functional in under 2 seconds what about all those ipTV's ? )
Please limit your posts to positive experiences or mentioning people who would be able to achieve it.
I hope this thread can be a positive engineering resource for those that need tight well engineered results !
Regards
John Jones
klricks
Re: Fast boot (sub second) of pi zero w - howto ?
Sat Jun 17, 2017 7:04 am
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
johnjones
Sat Jun 17, 2017 8:04 am
Thats not very positive or useful so I was wondering if anyone had any positive experience in booting under a second and capturing an image here
Again I find it hard to believe the designers of a videocore device did not think of bringup in under a second
John
Sat Jun 17, 2017 8:13 am
johnjones wrote:Again I find it hard to believe the designers of a videocore device did not think of bringup in under a second
Why do you find it hard to believe? The VC was designed for use in mobile phones. How long does your mobile take to start up from cold?
johnjones
Sat Jun 17, 2017 8:37 am
I presumed they actually engineered it for IP television and the mobile phone / ipod was simply a way to earn money, either way it seems odd that the system has to spend so long initialising...
Again has anyone had any positive experience ?
mahjongg
Sat Jun 17, 2017 10:07 am
most IP tv's do not really turn off, I don't think that any device with the complexity of a real OS can turn on and be ready in seconds, even if they have all their software in permanent storage (ROM) it will take much more than a few seconds to initialise all devices that must be initialised.
in contrast, the PI has nor permanent built in storage at all (except for a tiny bit of boot code) and has to load *everything* from sd-card.
In short, no!
sub seconds boots are impossible.
On the other hand, energy wise, there is no real reason to shut down at all.
The fastest demo I can recall having seen booted to a simple game in something like 5 seconds, and all that had to do in these 5 seconds was to load a single piece of a few hundred kilobyte of bare metal code, no OS involved, and nothing to initialise.
dwelch67
Sat Jun 17, 2017 1:32 pm
the closest you could come to this is probably what some laptops do and that is they have an arm (non-x86) keep the dram and other things alive, they hibernate basically by taking a snapshot of the system and keeping the snapshot in ram powered on, then can bring up the main cpu which is relatively fast, then restore state then run.
set top boxes, your car stereo, ip enabled tvs, etc these things dont completely turn off. Things take a while to come up, dram init, getting on the network, wired or wireless, all these things take time, you cannot create/replace the laws of physics just because you wish to.
If you want something to boot fast you have to design it from the ground up, that doesnt guarantee you can meet any time you want, and most of the time it is an illusion to the user, the thing is partially on all the time and only the display is off, or the processor is put in a sleep mode if it is a major power consumer, etc. (like your phone or set top box, off means simply turn off the video). You cannot take any arbitrary system and change its design after it is in production and out in the wild. You can certainly re-write the GPU boot code and make the pi boot faster, you are more than welcome to do that, how fast can you boot? Well you let us know when you get there. You would need to do without video, usb, and dram at a minimum to really get the speed improvement, and I dont think there is enough if any on chip ram to do anything useful, but will see let us know what you find. You certainly wont be running linux BTW.
You want something that can take a picture in a second, first off why would you use a pi, second you are going to be leaving something if not everything on. Perhaps shop around through the myriad of camera modules, and take a microcontroller on it (which most certainly can boot within a second, and can come out of low power mode even faster than boting), combine the two, done.
dwelch67
Sat Jun 17, 2017 1:36 pm
and yes, if you take a pi and write your code for the GPU instead of the arm, treat it like a microcontroller, yes you could boot and take a picture that fast depending on the camera, you might have to leave the camera module on all the time, depends on what you find. depending on what you learn about the gpu you might have it be a very short program that starts the arm immediately, assuming you can find some ram you can get the arm up that fast as well, but in either case the camera may be slow, and you need enough ram, or better get a camera module with ram on it. You could replace the gpu bootloader, so that it takes the picture first into the ram of the camera module, then does a normal boot however long that takes, then you can use linux on the arm to extract that image and send it somewhere if that is what you need to do with the image.
dwelch67
Sat Jun 17, 2017 7:36 pm
How fast does it boot from power on to the arm coming up? Not linux but the arm coming out of reset? Normal boot, no modifications to the GPU code, no config.txt, very small arm binary, maybe enough to set a gpio pin for your scope. Have you measured it? What time did you get?
What camera are you thinking of using?
Martin Frezman
Sat Jun 17, 2017 9:34 pm
Which no longer exists.
What happened to it? Did OP single-handedly delete the thread?
Did he get a mod to remove it?
If this post appears in the wrong forums category, my apologies.
klricks
Sat Jun 17, 2017 9:49 pm
It was a duplicate thread in which the OP already had gotten several answers.
Gavinmc42
Sat Jun 17, 2017 11:23 pm
Ultibo will boot in <2 seconds, but the VC4 accelerated stuff like camera interface is not working, yet.
Fast boot camera is one of the apps I want to use Ultibo for.
You probably won't get less than 3 seconds as the camera ISP still has to do white balance etc.
An always on OS would be the way to go, depending on what needs to be running 30-80ma could be the current drain.
Baremetal VC4 coding could be one way to do it, but you would be looking at a custom start.elf.
As start_x.elf has all the camera magic code, adding an extra "power on, take image", code could be done here.
RPF would have to be the ones to write this code as they have the secret sauce recipes.
There may not even be a need to fire up the ARM as the VC4 could write the image to SDcard.
I'm dancing on Rainbows.
johnjones
Sun Jun 18, 2017 7:21 am
Thanks Gavinmc42
Your comments are helpful and Positive !
Your probably right about the 3 seconds as the camera ISP might be limitation I guess thats why ARM ltd are doing their own.
30mA seems a lot to me for a battery powered system that has to last weeks
A nice addition to the firmware would be to initialise the camera and take a snapshot but I think I would have to do this myself which would involve a lot of work in initialising the other subsystems for little benefit, this is why other systems have open firmware...
Pretty much all embedded systems I've used initialise very fast under 1 second, however things like phones spend a huge amount of time securing their boot process by checking all the binaries have not been patched and checking battery voltage etc, TV systems, radio systems and transport systems will initialise under a second and subsystems like disk and network might not be fully available but the schedular is up and busy...
I suppose it comes down to understanding other peoples point of view and having a broader understanding of the world around you...
John
mikerr
Sun Jun 18, 2017 9:16 am
Boot time can be down to 2 seconds with bare metal stuff - but that's not much use if you want to use linux niceties and peripherals.
The fastest I managed to boot and take a picture using the CSI camera is 7 seconds using Arch
viewtopic.php?f=43&t=80421
Martin Frezman
Sun Jun 18, 2017 10:21 am
Hence my question. I don't see how he could have deleted it once it had (substantive) responses from other people.
And I don't think mods would do that sort of thing either. Hence my question.
Gavinmc42
Sun Jun 18, 2017 12:31 pm
Thanks mikerr, I did not know arch was that fast.
Never really played with it because the first few Pi years I had no Internet access.
I might see how fast I can boot piCore, normally it is 12-15 secs.
mahjongg
Sun Jun 18, 2017 6:50 pm
Martin Frezman wrote:And I don't think mods would do that sort of thing either. Hence my question.
Nope we do! if both identical posts have answers we simply choose the one with the least answers (but no promise here).
Simply do not post duplicate questions.
The other one should have the same subject line so you can search for it if you know it.
OutsourcedGuru
Thu Jun 29, 2017 11:03 pm
Back when the Earth was cooling and dinosaurs still roamed the land, I owned a very cool computer from Radio Shack which would 100% boot in three seconds flat. I'm not kidding. Pretty sure it was the Tandy 1000 EX.
The way it achieved this was by storing MS-DOS v2.11 in ROM. Upon bootup, it either copied the boot image sidesways to RAM or something clever.
That said, an iOS device can wake up from a sleeping state instantaneously. I would guess that you need to think in these terms: leave it booted but have it wake via GPIO with a button.
mikerr
Fri Jun 30, 2017 7:48 am
Often it's about user experience.
One trick is to show a (non responsive) GUI screenshot long before the system has fully booted in the background.
The user thinks it's booted fast - but doesn't actually click buttons / touch screen for several seconds....
Mobile devices do that - deceiving the user or good UI ?
Gavinmc42
Mon Jul 03, 2017 11:40 am
Yep turn on PC, put kettle on, stare at screen, booting.
Go make coffee, stare at the screen some more, booting Win 7.
OS finally booted, run browser to check emails, stare at screen some more.
That is current mainstream user experience.
Wonder if there is an app that can turn on the PC while I am still driving in?
They can do it for Pizza's.
Raspbian on the other hand, it boots and I stare at the screen until the Cambridge screensaver fires up and then I stare some more at the drone footage :lol: When is the movie coming out?
Does anyone have a drone service? Virtual 3D drone tours of interesting places and sites.
Youtube 3D holidays for those who can no longer find the time or money to go there.
Hmm a Pi screensaver on the TV, showing random places and sites, has to be better than most TV shows these days.
Just been playing with Peter Lemon's baremetal stuff, He has even done V3D baremetal :o
https://github.com/PeterLemon/RaspberryPi
And he has done a baremetal video player, well only 320x240 but it's a start.
Even a tiny 500byte Arm kernel's does not boot in less than a second.
It would have to be done in the VC4, but white balance etc will still slow it down.
Hmm, could the VC4 start the camera ISP etc while the Arm boots?
Apple has Metal 2, others are working on Vulkan, MS is working on getting closer to the GPU too.
Is RPF working on some thing similar to let users get closer to the metal?
How old is OpenGL etc.
Mon Jul 03, 2017 3:21 pm
OutsourcedGuru wrote:Back when the Earth was cooling and dinosaurs still roamed the land, I owned a very cool computer from Radio Shack which would 100% boot in three seconds flat. I'm not kidding. Pretty sure it was the Tandy 1000 EX.
BBC micro would boot in less than 1s I think.
But it was a 8bit micro, with no ethernet, no wifi, no USB, no hires graphics, no desktop, no bluetooth, in fact pretty much nothing needed to be 'started' except the command line. So there are reasons why it was so quick.
All mobile devices sleep, so all the drivers are loaded even when the device appears to be off. So they can start up pretty quickly. For actual boot times, turn them completely off then time how long it takes Android, for example, to get to a desktop. Slower than a Pi....
Please direct all questions to the forum, I do not do support via PM.
jahboater
Mon Jul 03, 2017 5:15 pm
My five year old Intel PC (Linux Mint 18 - Mate desktop) ...
$ systemd-analyze
Startup finished in 1.758s (kernel) + 751ms (userspace) = 2.510s
Mon Jul 03, 2017 7:51 pm
jahboater wrote:My five year old Intel PC (Linux Mint 18 - Mate desktop) ...
$ systemd-analyze
My relatively new PC, latest Ubuntu running Unity. 16GB RAM Intel® Core i5-6500 CPU @ 3.20GHz × 4, with OS on SSD
Startup finished in 1.603s (kernel) + 10.426s (userspace) = 12.030s
So, the Pi doesn't seem toooo slow..
Mon Jul 03, 2017 8:37 pm
$ systemd-analyze
That's a little faster than my laptop, Ubuntu 16.04 running Unity. 16GB RAM Intel® Core i7-6920HQ CPU @ 2.90GHz x 4, with OS on SSD
Startup finished in 6.695s (kernel) + 12.796s (userspace) = 19.492s
There's a lot of stuff running on it. And those pretty numbers don't really relate to the time from power on to desktop login, that's quite a bit longer.
jahboater
Mon Jul 03, 2017 8:55 pm
jamesh wrote: So, the Pi doesn't seem toooo slow..
Yes, no complaints at all - my Pi3 ...
$ systemd-analyze
Startup finished in 1.280s (kernel) + 4.836s (userspace) = 6.116s
Considering the difference in physical size, price, and power consumption .... !
Return to “Bare metal”
Who is online
Users browsing this forum: No registered users and 4 guests
