DexOS
Re: Raspberry Pi OS
Sun Jan 12, 2014 6:44 am
jum wrote:Would be cool to be able to write and run the DexBasic programs while in DexOS. (old-school 8-bit computer style).
I was waiting until i finished the the interpreter, which is nearly done.
Then i just need to add a text editor.
@bertwert , Your welcome and sure i will PM.
Batteries not included, Some assembly required.
Alrro
Re: Raspberry Pi OS
Sun Jan 12, 2014 12:29 pm
Hi, cool OS!
What Assembler variation do you use? Do you use also another one?
Trying to make my OS and don't know what to start with :lol:
Alvaro
tufty
Re: Raspberry Pi OS
Sun Jan 12, 2014 1:47 pm
DexOS wrote:Then i just need to add a text editor.
http://www.finseth.com/craft/ may be of some use. Obviously, it's aimed at lisp/scheme and *ahem* emacs-like editors, but the basic principles should hold
b_w_johan
Re: Raspberry Pi OS
Thu Apr 03, 2014 5:24 pm
I was wondering if DexOS was still available somewhere?
Or is this project shutdown and everything deleted?
(found several links on both this forum and online to the DexOS project, but they all lead to dead ends or inactive webhosting)
DexOS
Re: Raspberry Pi OS
Thu Apr 03, 2014 9:12 pm
The projects are no longer dev, but if you pm me a email address i will send you the latest code.
Or if you can wait a little longer, as i am going to set up a github with the code.
jtokarchuk
Re: Raspberry Pi OS
Mon Apr 07, 2014 4:27 pm
I would love the source to this, as well as I would (if you don't mind) like a copy of minidos (as your dex-os site is down)
can contact me at justintokarchuk[at]gmail[dot]com if you need. (unable to pm apparently yet? ;o)
b_w_johan
Re: Raspberry Pi OS
Thu Feb 26, 2015 5:16 pm
Hey Dex, haven't had reply on my PM and well i haven't seen an update in this topic about github so i was wondering if you're OK?
DexOS
Re: Raspberry Pi OS
Sat Feb 28, 2015 2:47 pm
Hi b_w_johan, sorry i did not see your PM.
I have now set up a github for the project https://github.com/dex-os/DexOS
And here's the web page http://dex-os.github.io/
And minidos source code is here:
https://web.archive.org/web/20140108065 ... iniDos.zip
Note: I will be adding the raspberry pi code this weekend, the above is for x86.
Return to “Bare metal, Assembly language”
