brekee12
Screen size setting
Sat Sep 17, 2016 11:45 am
Hello!
I am trying to know bare metal programming in assembly. The goal is graphical routines, but I already hit the wall with change the resolution of the screen. If you have some time please spend some time on my code to see why it stops before it sets the screensize.
Thank you in advance!
graphics02.zip
(26.18 KiB) Downloaded 72 times
Brekee12
on a Raspberry B+ with whezzy, two Zero with Jessie Light
Laurens-wuyts
Re: Screen size setting
Sun Sep 18, 2016 5:23 pm
I think it has to do with the resolution you use. Sometimes the GPU doesn't accept a specific resolution.
I use 1920x1080 which works fine. You could also try 640x480 to test the code. If this works, it's probably an unsupported resolution.
I compared it with code I have running fine, and I don't see much fundamental difference. ;)
Laurens
brekee12
[SOLVED] Screen size setting
Mon Sep 19, 2016 6:42 am
Thank you for spending some time on my code. I replaced my mailbox routin to Alex Chadwick's routin and it seems to work fine. Now I can continue to debug the other routins, because I have seen something on the screen.
Brekee12
