Except that this branch hangs during boot, just before mounting rootfs:
U-Boot 2016.03-00640-gc805f24 (May 30 2016 - 15:53:52 +0200)
DRAM: 944 MiB
RPI 3 Model B (0xa02082)
boot regs: 0x00000000 0x00000000 0x00000000 0x00000000
MMC: bcm2835_sdhci: 0
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
In: serial
Out: lcd
Err: lcd
Net: Net Initialization Skipped
No ethernet found.
starting USB...
USB0: Core Release: 2.80a
scanning bus 0 for devices... 3 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
scanning usb for ethernet devices... 1 Ethernet Device(s) found
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr.uimg
reading /boot.scr.uimg
285 bytes read in 10 ms (27.3 KiB/s)
## Executing script at 02000000
reading bcm2837-rpi-3-b.dtb
5736 bytes read in 30 ms (186.5 KiB/s)
reading image
8326728 bytes read in 709 ms (11.2 MiB/s)
## Flattened Device Tree blob at 00000100
Booting using the fdt blob at 0x000100
reserving fdt memory region: addr=0 size=1000
Loading Device Tree to 000000003ab30000, end 000000003ab34667 ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.5.0+ (
[email protected]) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) ) #2 SMP PREEMPT Tue May 31 11:12:06 CEST 2016
Boot CPU: AArch64 Processor [410fd034]
cma: Reserved 16 MiB at 0x0000000039800000
PERCPU: Embedded 20 pages/cpu @ffffffc03af9d000 s41368 r8192 d32360 u81920
Detected VIPT I-cache on CPU0
CPU features: enabling workaround for ARM erratum 845719
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 237888
Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait rw
log_buf_len individual max cpu contribution: 4096 bytes
log_buf_len total cpu_extra contributions: 12288 bytes
log_buf_len min size: 16384 bytes
log_buf_len: 32768 bytes
early log buf free: 15128(92%)
PID hash table entries: 4096 (order: 3, 32768 bytes)
Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
software IO TLB [mem 0x34a00000-0x38a00000] (64MB) mapped at [ffffffc034a00000-ffffffc0389fffff]
Memory: 857560K/966656K available (5440K kernel code, 371K rwdata, 2004K rodata, 312K init, 211K bss, 92712K reserved, 16384K cma-reserved)
Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc0000000 - 0xffffffbdc0ec0000 ( 14 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc03b000000 ( 944 MB)
.init : 0xffffffc0007c6000 - 0xffffffc000814000 ( 312 KB)
.text : 0xffffffc000080000 - 0xffffffc0007c5b74 ( 7447 KB)
.data : 0xffffffc000814000 - 0xffffffc000870e48 ( 372 KB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
Build-time adjustment of leaf fanout to 64.
RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
NR_IRQS:64 nr_irqs:64 0
sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
bcm2835: system timer (irq = 35)
Architected cp15 timer(s) running at 19.20MHz (phys).
clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Console: colour dummy device 80x25
Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
ASID allocator initialised with 65536 entries
Detected VIPT I-cache on CPU1
CPU1: Booted secondary processor [410fd034]
Detected VIPT I-cache on CPU2
CPU2: Booted secondary processor [410fd034]
CPU3: failed to come online
Brought up 3 CPUs
SMP: Total of 3 processors activated.
CPU: All CPU(s) started at EL2
alternatives: patching kernel code
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
cpuidle: using governor ladder
cpuidle: using governor menu
vdso: 2 pages (1 code @ ffffffc000819000, 1 data @ ffffffc000818000)
hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
DMA: preallocated 256 KiB pool for atomic allocations
Serial: AMBA PL011 UART driver
HugeTLB registered 2 MB page size, pre-allocated 0 pages
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
clocksource: Switched to clocksource arch_sys_counter
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
FS-Cache: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
kvm [1]: error: no compatible GIC node found
kvm [1]: timer IRQ4
kvm [1]: 8-bit VMID
kvm [1]: Hyp mode initialized successfully
futex hash table entries: 1024 (order: 5, 131072 bytes)
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(1.183:1): initialized
FS-Cache: Netfs 'nfs' registered for caching
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
fuse init (API version 7.24)
9p: Installing v9fs 9p2000 file system support
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
console [ttyS0] disabled
3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 61, base_baud = 31250000) is a 16550
console [ttyS0] enabled
Unable to detect cache hierarchy from DT for CPU 0
loop: module loaded
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <
[email protected]>
usbcore: registered new interface driver smsc95xx
3f980000.usb supply vusb_d not found, using dummy regulator
3f980000.usb supply vusb_a not found, using dummy regulator
dwc2 3f980000.usb: Configuration mismatch. dr_mode forced to host
dwc2 3f980000.usb: DWC OTG Controller
dwc2 3f980000.usb: new USB bus registered, assigned bus number 1
dwc2 3f980000.usb: irq 41, io mem 0x00000000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ehci-platform: EHCI generic platform driver
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-pci: OHCI PCI platform driver
ohci-platform: OHCI generic platform driver
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
ledtrig-cpu: registered to indicate activity on CPUs
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
bcm2835-mbox 3f00b880.mailbox: mailbox enabled
NET: Registered protocol family 17
9pnet: Installing 9P2000 support
Key type dns_resolver registered
Registered cp15_barrier emulation handler
Registered setend emulation handler
registered taskstats version 1
3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 72, base_baud = 0) is a PL011 rev2
mmc0: SDHCI controller on 3f300000.sdhci [3f300000.sdhci] using PIO
raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-24 12:37
Console: switching to colour frame buffer device 100x30
hctosys: unable to open rtc device (rtc0)
... <- hangs here
I've used this Debian image as a starting point[*] and i've noticed that the kernel / dtb that came with this image is significantly larger than the one produced by zeldin's tree.
Moreover, substituting the armstubs / u-boot that came in this Debian image with one produced by upstream trees, doesn't work either, since i get a solid hang on boot before the serial has any chance to spit out any character.
I guess some investigation is needed.
1:
viewtopic.php?p=952679#p952679
