its a builtin gcc function. you need libgcc.a or code them yourself.
the arm cpu doesnt have % and / in the core as commands, so they have to be emulated
.macro ARM_DIV_BODY dividend, divisor, result, curbit
#if __LINUX_ARM_ARCH__ >= 5
clz \curbit, \divisor
clz \result, \dividend
sub \result, \curbit, \result
mov \curbit, #1
mov \divisor, \divisor, lsl \result
mov \curbit, \curbit, lsl \result
mov \result, #0
@ Division loop
1: cmp \dividend, \divisor
subhs \dividend, \dividend, \divisor
orrhs \result, \result, \curbit
cmp \dividend, \divisor, lsr #1
subhs \dividend, \dividend, \divisor, lsr #1
orrhs \result, \result, \curbit, lsr #1
cmp \dividend, \divisor, lsr #2
subhs \dividend, \dividend, \divisor, lsr #2
orrhs \result, \result, \curbit, lsr #2
cmp \dividend, \divisor, lsr #3
subhs \dividend, \dividend, \divisor, lsr #3
orrhs \result, \result, \curbit, lsr #3
cmp \dividend, #0 @ Early termination?
movnes \curbit, \curbit, lsr #4 @ No, any more bits to do?
movne \divisor, \divisor, lsr #4
bne 1b
.endm
.macro ARM_DIV2_ORDER divisor, order
clz \order, \divisor
rsb \order, \order, #31
.endm
.align 5
.globl __divsi3
.globl __aeabi_idiv
__divsi3:
__aeabi_idiv:
cmp r1, #0
eor ip, r0, r1 @ save the sign of the result.
beq Ldiv0
rsbmi r1, r1, #0 @ loops below use unsigned.
subs r2, r1, #1 @ division by 1 or -1 ?
beq 10f
movs r3, r0
rsbmi r3, r0, #0 @ positive dividend value
cmp r3, r1
bls 11f
tst r1, r2 @ divisor is power of 2 ?
beq 12f
ARM_DIV_BODY r3, r1, r0, r2
cmp ip, #0
rsbmi r0, r0, #0
mov pc, lr
10: teq ip, r0 @ same sign ?
rsbmi r0, r0, #0
mov pc, lr
11: movlo r0, #0
moveq r0, ip, asr #31
orreq r0, r0, #1
mov pc, lr
12: ARM_DIV2_ORDER r1, r2
cmp ip, #0
mov r0, r3, lsr r2
rsbmi r0, r0, #0
mov pc, lr
Ldiv0:
str lr, [sp, #-4]!
bl __div0
mov r0, #0 @ About as wrong as it could be.
ldr pc, [sp], #4
