Sonny05
Boot code from SD card (other possibilities)
Sat Jun 27, 2015 5:45 pm
Hi all,
I have one question. For boot code to raspberryPi I use these steps:
1, remove SD card from raspberryPI and turn off.
2, create new file with name "kernel.img".
3, insert SD card to PC.
4, copy file "kernel.img" to SD card
5 remove SD card from PC
6, insert SD card to raspberryPI and turn on.
7, repeat 1step
This procedure is slow and uncomfortable.
Have anyone experience with faster procedure?
Is one with possibility this converter USB to UART? http://shop.pimoroni.com/products/usb-t ... sole-cable
Re: Boot code from SD card (other possibilities)
Sat Jun 27, 2015 7:28 pm
Sonny05 wrote: Have anyone experience with faster procedure?
When I was playing with bare metal I'd build on a RPi running Raspbian and write the bootable SDCard using a USB SDCard reader. You can pull the power on the bare metal machine without risk to the SDCard until you start writing data on the card.
Unless you program your bare metal system to drive a serial interface it doesn't have any way to talk to the outside world. That's the fundamental difference between running an OS and running bare metal.
Joe Schmoe
Sat Jun 27, 2015 7:38 pm
Although I haven't seen him 'round here in quite a while, way back when, someone named 'dwelch' posted a bunch of stuff about how to do this using the serial port.
You can probably find it on a search of the forum and/or find his website which has all the details.
Sonny05
Sat Jun 27, 2015 8:07 pm
His website I found:https://github.com/dwelch67/raspberrypi
I wanted to know who has what experience and what I need to buy.
jspeccy
Sat Jun 27, 2015 8:42 pm
Sonny05 wrote:His website I found:https://github.com/dwelch67/raspberrypi
You need a USB<->serial-3V3 cable like this: Raspberry Pi Cable, TTL-232R-RPI and put the firmware files bootcode.bin, fixup.dat, start.elf and kernel.img from Welch's bootloader05 sample into the SD.
Then, you can transfer files from PC to PI using the good old XMODEM protocol up to 115200 bps. I use a slightly modified bootloader05 to preserve the r0-r2 registers and allow transfers up to 1 Mbps.
It's an easy task. :)
Sonny05
Sat Jun 27, 2015 8:56 pm
Thanks jspeccy,
and what program you use to transfer files from PC to RPI?
jspeccy
Sat Jun 27, 2015 8:59 pm
Sonny05 wrote:Thanks jspeccy,
'sx' program from Fedora 22 'lrzsz' package.
Sonny05
Sat Jun 27, 2015 9:30 pm
Thanks again
tgritchie
Tue Jun 30, 2015 11:34 am
Hi - I, too, started out with dwelch67s serial bootloader code to avoid the tedium of swapping SD cards in and out but now use Jamie Iles' remote debug code which not only allows loading of images thru the serial port but also some (admittedly limited) debugging using GDB. Check it out here: https://github.com/jamieiles/rpi-gdb
Trevor
