Nvreformat
[Experimental] Loading a kernel using the ethernet port
Mon May 04, 2015 6:48 am
I've written an utility that does allow you to boot a custom kernel using the RPi onboard ethernet port.
It's still in a very early stage, so it may have some bugs that I don't know yet.
Info about usage and compilation can be found at:
https://github.com/Nvreformat/Etherboot
Issues:
*Although it has protection against packet loss, it looks like it doesn't work properly. Sometimes it will stop while transferring the kernel and halt there.
Any help is appreciated.
kriss
Re: [Experimental] Loading a kernel using the ethernet port
Mon May 04, 2015 9:57 am
hi
i didn't read all your code but i think it should have support for usb too ;)
is it based on a custom buffered "kexec" ?
if yes multi-boot from anything is ours with your code ;)
do you plan to add some small tools to rescue a partition/os or to just be able to work ?
thanks
Nvreformat
Mon May 04, 2015 11:08 am
kriss wrote:hi
You mean being able to boot kernels from a USB stick?
kriss wrote:is it based on a custom buffered "kexec" ?
I didn't know what kexec was until I read its Wikipedia article right now, so I guess that no.
If it helps, once the new kernel is booted up, it gains full control of the system and the old kernel won't be used anymore.
What this utility does is basically what the RPi does when it's powered on. In fact, I wrote it so that I didn't have to pull/put the SD card evertrime I updated my kernel
kriss wrote:do you plan to add some small tools to rescue a partition/os or to just be able to work ?
thanks
Please elaborate more
kriss
Mon May 04, 2015 11:25 am
your code goal is near kexec but best
usb stick and also wire (without ethernet protocol)
tools needed : editor, assembler, fsck ...
anyway why don't you have a RPI2 ???
rst
Mon May 04, 2015 11:30 am
Nvreformat wrote:Issues:
I have pushed a small change to the USPi library to GitHub. There was an issue which caused the USB driver to halt at least in a multi-core configuration (found with a stress test with Circle on the Pi 2). Maybe this problem also did happen here. Perhaps it helps.
Nvreformat
Mon May 04, 2015 12:22 pm
Thanks, I'll update it as soon as I get home.
Now that you mention it, I recall an issue regarding USPi where if you started the driver and let it idle for approx 2 minutes then sometimes USPiReceiveFrame would always fail even though you could see the led blink in the ethernet port when you send some data.
rst
Mon May 04, 2015 2:56 pm
Nvreformat wrote:Now that you mention it, I recall an issue regarding USPi where if you started the driver and let it idle for approx 2 minutes then sometimes USPiReceiveFrame would always fail even though you could see the led blink in the ethernet port when you send some data.
I tried to reproduce this problem with and without the last change applied using the USPi ethernet sample but without success. I waited 5 minutes until I attached the Ethernet cable to a Pi 1 B+ and it did receive my ARP pings.
Of course the received frames have to be addressed to this MAC address or must be broadcasts to be successfully received. There is no promiscous mode implemented. I think the LED flashes on every frame the Ethernet controller "sees" on the connector.
kriss
Mon May 04, 2015 5:50 pm
continue the good work (you two)
i'll be happy to disasm & optimize it ;)
Return to “Bare metal, Assembly language”
