xdai
Does RPi2 honor "kernel_address"?
Sun Mar 01, 2015 10:17 am
I am asking because I put following in config.txt:
kernel=loader.bin
kernel_address=0x00000000
So I was trying to ask start.elf to load "loader.bin"(my bare metal program) to 0x00000000. I spend one day to debug some weird behavior of loader.bin, and it turned out it was loaded to 0x8000 instead of 0x0000.
Can someone confirm that "kernel_address" should actually work? I am wondering maybe I just missed some obvious point...
mimi123
Re: Does RPi2 honor "kernel_address"?
Sun Mar 01, 2015 11:19 am
xdai wrote:I am asking because I put following in config.txt:
kernel=loader.bin
you should not use kernel_address but kernel_old=1 to load @absolute zero
dom
Sun Mar 01, 2015 11:21 am
By default the firmware inserts some startup code at 0x0 and inserts the kernel ATAGs at 0x100. Actual kernel is loaded at 0x8000.
Add kernel_old=1 to avoids prepending the boot code.
Add disable_commandline_tags=1 to avoid populating the ATAGs.
Set both of those and your kernel will be loaded at 0 (or kernel_address if specified).
xdai
Mon Mar 02, 2015 8:12 am
Thanks, that's good to know. Does that mean "kernel_address" will honor any other addres settings other than zero? I assume so.
(Yes I understand we still need to handle ATAG).
mrvn
Wed Mar 04, 2015 4:29 pm
dom wrote:Set both of those and your kernel will be loaded at 0 (or kernel_address if specified).
Does that also apply to the extra cores on the RPi2? I assume normaly the bootcode at 0 would halt the extra cores till something is written to their mailboxes. So will they all power up and start executing the code at 0 without waiting?
dom
Wed Mar 04, 2015 6:46 pm
All cores start running from zero after reset. The default boot code makes 3 cores wait for a signal from first core.
If you provide your own boot code, you will probably need to do something similar (or you will end up running the same code 4 times in parallel...)
rln
Wed Jan 20, 2016 2:11 pm
dom wrote:By default the firmware inserts some startup code at 0x0 and inserts the kernel ATAGs at 0x100. Actual kernel is loaded at 0x8000. Add kernel_old=1 to avoids prepending the boot code. Add disable_commandline_tags=1 to avoid populating the ATAGs. Set both of those and your kernel will be loaded at 0 (or kernel_address if specified).
I would like to set "kernel_address" to a very high address but seems it doesn't work nowadays. Very old firmwares accept arbitrary addresses but recent versions only work with either 0x0 or 0x8000. Would it be possible to get the old behaviour back?
Author of the robust Nard distro http://www.nard.se
