f4nt4st1ck
i created a Led assembly that makes ON/OFF in a loop, but how can i create an SOS code in assembly?
Tue Dec 03, 2019 3:38 pm
Hello Guys
Can someone help me?
LdB
Re: How can i create S.O.S morse code @ Assembly
Tue Dec 03, 2019 4:12 pm
Turn the on off into a subroutine with a delay time (long and short) carry the delay value in R0
So an S is
Flash led(short)
Fixed_Delay
Flash led(short)
Fixed_Delay
Flash led(short)
Fixed_Delay
An O is
Flash led(long)
Fixed_Delay
Flash led(long)
Fixed_Delay
Flash led(long)
Fixed_Delay
f4nt4st1ck
Tue Dec 03, 2019 4:34 pm
Hi LdB
how exactly do you mean it?
LdB
Wed Dec 04, 2019 12:50 am
Just refactor your code with subroutines, let me do it long form
The hint there is you can refactor it even smaller by simply adding more functions, I added just two
LED_ON_FOR_DELAY_LOOP, LED_OFF_FOR_DELAY_LOOP
You could actually bring them down to a single function with a more complex entry
.section .init
.global _start
.equ BASE,  0x3f200000 @Base address
.equ GPFSEL2, 0x08			@FSEL2 register offset
.equ GPSET0,  0x1c			@GPSET0 register offset
.equ GPCLR0,0x28			@GPCLR0 register offset
.equ SET_BIT3,   0x08		@sets bit three b1000
.equ SET_BIT21,  0x200000 	@sets bit 21
.equ COUNTER, 0xf0000
.equ OFF_DELAY, 0xf0000
.equ LONG_DELAY, 0xf0000
.equ SHORT_DELAY, 0x40000
_start:
ldr r0,=BASE
ldr r2,=COUNTER
ldr r1,=SET_BIT3
str r1,[r0,#GPFSEL2]
ldr r1,=SET_BIT21
str r1,[r0,#GPSET0]
ldr r3,=SET_BIT3
str r3,[r0,#GPFSEL2]
Infinite_loop:
    ;@ >>>> send S which is 3 short ons <<<<<
    ldr r2, SHORT_DELAY  ;@ short delay
    ldr r1,=SET_BIT3          ;@ port to turn on
    bl  LED_ON_FOR_DELAY_LOOP  ;@ call function
    ldr r2, OFF_DELAY       ;@ normal off delay
    ldr r1,=SET_BIT3         ;@ port to turn off
    bl  LED_OFF_FOR_DELAY_LOOP ;@ call function
    ;@ >>>> send O which is 3 long ons <<<<<
    ldr r2, LONG_DELAY  ;@ long delay
    ;@ >>>>  OUTPUT EXTRA LONG OFF BETWEEN WORDS <<<<<
    ldr r2, OFF_DELAY *4      ;@ normal off delay
b Infinite_loop
@#		LED_ON_FOR_DELAY FUNCTION
@#		Entry: Set R0 base,   R1 carries the port value to set,  R2 carries delay count
@#          Trashed: R10
LED_ON_FOR_DELAY_LOOP:
    str r1,[r0,#GPSET0]  ;[email protected] turn the LED ON
    mov r10,#0
    delay:@loop to large number
      add r10,r10,#1
      cmp r10,r2      ;@ Remember R2 is carrying the delay count
      bne delay
      bx  lr
@#		LED_OFF_FOR_DELAY FUNCTION
@#		Entry: Set R0 base,   R1 carries the port value to clear,  R2 carries delay count
@#          Trashed: R10
LED_OFF_FOR_DELAY_LOOP:
    str r1,[r0,#GPCLR0]  ;[email protected] turn the LED OFF
    mov r10,#0
    delay1:@loop to large number
      add r10,r10,#1
      bne delay1
      bx  lr
f4nt4st1ck
Re:
Wed Dec 04, 2019 1:30 am
.section .init
.global _start
_start:
ldr r0,=BASE
ldr r2,=COUNTER
ldr r1,=SET_BIT3
ldr r1,=SET_BIT21
str r1,[r0,#GPSET0]
ldr r3,=SET_BIT3
Infinite_loop:
b Infinite_loop
@#          Trashed: R10
    mov r10,#0
      add r10,r10,#1
      bne delay
      bx  lr
@#          Trashed: R10
    mov r10,#0
      add r10,r10,#1
      bne delay1
      bx  lr
Ah now i got it, make a simple function end of a loop and use wir "bl" - thank u mate!
