Gavinmc42
Barebox
Thu May 16, 2019 6:12 am
I have used U-boot on Linux devices before but this one is new to me.
https://www.barebox.org/doc/latest/user ... anual.html
USB and framebuffer are interesting, this is a bit more than uart console.
There is stuff in there that I have seen in Busybox and Toybox, i2cprobe(i2cdetect?) etc
Has anyone tried it on Pi's?
I'm dancing on Rainbows.
epoch1970
Re: Barebox
Thu May 16, 2019 12:04 pm
I see that as the quarrel between germans brothers (Denx and Pengutronix)
If you read this old presentation the reasons for forking u-boot into barebox exposed back in the day are, I believe, not all still relevant today.
In the meantime I don't think Barebox has acquired a very large user base. I could be wrong.
hippy
Re: Barebox
Thu May 16, 2019 9:14 pm
I hadn't heard of it either and it looked interesting to me. Managed to get it built on my Pi 3B but haven't had time to check it boots. Took about 5 minutes in total -
sudo apt-get install bison
sudo apt-get install flex
sudo apt-get install lzop
cd ~
git clone https://github.com/avian2/barebox.git
cd barebox
export ARCH=arm
make rpi_defconfig
make -j1
sudo cp images/barebox-raspberry-pi-3.img /boot/barebox.img
Acknowledgements to : https://www.tablix.org/~avian/blog/arch ... om_barebox
Gavinmc42
Re: Barebox
Fri May 17, 2019 1:51 am
Thanks guys, interesting links.
Barebox is a mix of boot loader and Linux
I like the options of choosing OS's.
With the network stuff, picking and loading the OS from a server?
Wonder if I can expand the framebuffer stuff into an OpenVG GUI.
This could be fun, it looks like a mini OS with integrated shell and editor :o
Could I toss away Linux?
hippy
Re: Barebox
Fri May 17, 2019 9:53 am
Those were my exact thoughts. Looks like a reasonably comprehensive 'bootable bare metal C' implementation which could be leveraged for other things. I had some fun building Windows PE set-ups back in the day and this looks similar for Linux.
Gavinmc42
Re: Barebox
Fri May 17, 2019 11:29 am
Bit longer on a Pi3B ;)
I think it defaults to serial console only, I get the 4 colour screen.
Time to play with make menuconfig, same method as Buildroot?
Yep looks like it , need ncurses dependencies first.
This could take a while, where is the frame buffer hiding?
Gavinmc42
Re: Barebox
Fri May 17, 2019 11:52 am
Generates a 362KB kernel so nice and small.
So baremetal I need to dig out a serial console gadget to see if is working.
Yep Buildroot stuff, so much fun working through those menu configs, not.
But at least I now have a C baremetal toolset that I am happy to work with.
Been trying small Linux, none small/simple enough to suit me.
Yocto was not bad, my Go based PunkOS OpenVG Demo Desktop just worked but still 600MB :lol:
hippy
Re: Barebox
Fri May 17, 2019 4:43 pm
Needing the serial console is why I haven't tried booting it yet. There's some docs here which may help -
Odd. Under 3 minutes for me on my 3B (non-plus), with the previous deleted and starting over again with cloning from .git
I wanted to add an "export KBUILD_OUTPUT=./build" as recommended by the documentation.
Time to play with make menuconfig, same method as Buildroot? ... where is the frame buffer hiding?
"Sort of" was how it felt to me. Not sure if just enabling framebuffer / console framebuffer is enough to get a USB keyboard + HDMI console working.
Please do post a 'How To' update if you get that working, move on to doing interesting things.
Gavinmc42
Re: Barebox
Fri May 17, 2019 11:23 pm
make -j1
I just copied your instructions, hit return just as I realized I had 4 cores - make -j4 ;)
All my uart to FTDI USB serial dongles are at work, might have to use another Pi and some wires.
That means cleaning up the desk and another monitor etc.
Time to make that portable serial console with LCD?
Wonder what I can use to make that, I know - Barebox ;)
Time also to learn about that overlay stuff, perhaps the display stuff uses that?
Got some A+'s that don't have a home, Serial LCD consoles?
Pi's = non stop learning.
Sometimes I feel like i'm living Wack-a-mole life, learn this, no learn that, don't forgot to learn those, google what I forgot I learned 2 years ago.....
That last one is annoying...
hippy
Re: Barebox
Sat May 18, 2019 12:39 am
make -j1
I have been bitten by "-j4" induced make failures in the past so have got into the habit of substituting with "-j1" which solved it back then. "make -j1" is the under 3 minute compilation I'm getting.
jahboater
Re: Barebox
Sat May 18, 2019 6:13 am
Or just "make", it defaults to one CPU.
I use
make -j `nproc`
Gavinmc42
Re: Barebox
Sat May 18, 2019 7:34 am
Barebox on Pi's goes back at least 2012 and is on noobs :o
Time to try Noobs and PINN and just see what is available these days.
Got so focused on my little world I don't notice other stuff, probably more it did not means anything to me at the time.
This does look like a way to play with a babyboot/Linux/shell which has devicetree support.
Because it complies much faster than the real Linux, it makes for quicker learning how Buildroot/devicetree work.
It has taken me years to learn enough to go back to things like this and AJ Starks OpenVG code that has just been sitting there for years.
Thanks to RPF having this forum that goes back to the start of Pi's, things are just siting there waiting for google to find them.
Wonder what other little gems are out there?
Gavinmc42
Re: Barebox
Sat May 18, 2019 8:11 am
Somethings are right in your face and you don't notice them :oops:
Noobs and PINN are mini boot OS's that let you pick OS's.
But they fire up with device tree stuff and HDMI console.
How do these two things work?
The Lite versions, not that small at 36 and 44MB.
procount
Re: Barebox
Sat May 18, 2019 11:07 am
If you add "rescueshell" to recovery.cmdline in noobs or pinn, it will dump you straight to a command shell (ash) to play about in.
Add "ssh" to pinn and you can remote into it as well.
Gavinmc42
Re: Barebox
Sat May 18, 2019 12:16 pm
Thanks, that's very interesting, more learning- tomorrow :D
I'm busy trying to figure out device overlays for 480x320 LCDs.
The 7"Pi LCD just worked, but the Waveshare and 4DSystems might need more than just a hour or two to sort out.
Drivers are older than the kernels I am using.
Gone back to PiCore 9.03 to try getting the LCDs working there first.
Might have to do hardware GPIO bitbanging,
Probably should spend some time learning device overlays, seems to be a trend.
HDMI is so much easier, Waveshare now have HDMI from 3.5", that configuration also reduce the thickness.
hippy
Re: Barebox
Sun May 19, 2019 1:43 pm
I'm no linux expert so it was mostly a case of 'if you don't know what you're doing; stick with what you know works'. When -j4 created problems I used -j1 to force single job and it worked so stuck with that. The document I read was not clear on what leaving -j out did. With hindsight, having read 'man make', I think it was a lack of clarity in that document over leaving -j out or just the number after -j out.
Thanks for the info and provoking me to go and properly read-up on make.
jahboater
Re: Barebox
Sun May 19, 2019 4:15 pm
For interest, I think make was around for decades before multi-core CPU's and the -j option.
Return to “Bare metal, Assembly language”
