plugwash
Problems with OTG Ethernet between two Pi zeros.
Sat Mar 23, 2019 3:24 pm
Someone I work with was planning to use USB OTG to interconnect a number of Pi zeros but he was running into low performance and sometimes crashes with various configurations.
I decided to try testing using the ethernet gadget with iperf, running the iperf server on the host pi 0 and the iperf client on the gadget pi 0. The performance reported was abysmal and I frequently got kernel panics from the host pi zero. I tried upgrading the host pi zero first to the latest packaged kernel/firmware and then to the rpi-update kernel/firmware. That seemed to reduce the incidence of kernel panics but not eliminate them.
Anyone else seen anything like this?
Aydan
Re: Problems with OTG Ethernet between two Pi zeros.
Wed May 08, 2019 9:51 am
Is this problem limited to zeros as host or could this also happen with a Pi3 as host?
I'm in the process of setting up a pi cluster with a clusterHat on a Pi3B+ and (for now) three zeros and I'll keep my eyes open for this.
Regards
Aydan
B.Goode
Wed May 08, 2019 9:58 am
At least one user thought it worked well enough to produce a hardware solution to support its deployment:
https://clusterhat.com
Aydan
Wed May 08, 2019 11:06 am
That's the one I'm using
Return to “Linux Kernel”
