lib/raid6/neon4.c:118:1: internal compiler error: in dwarf2out_frame_debug_adjust_cfa, at dwarf2cfi.c:1078
Posted: Tue Jul 10, 2018 8:43 am
by siva93krishna
Hi ,
I am facing Below issue while trying to cross compile kernel for RPI3.
followed below link .
https://www.raspberrypi.org/documentati ... uilding.md
Log :
[email protected]:~/rpi/linux$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- zImage modules dtbs
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
CHK include/generated/bounds.h
CHK include/generated/timeconst.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
CHK scripts/mod/devicetable-offsets.h
CHK include/generated/compile.h
CHK kernel/config_data.h
CC [M] lib/raid6/neon4.o
lib/raid6/neon4.c: In function ‘raid6_neon4_gen_syndrome_real’:
Please submit a full bug report,
with preprocessed source if appropriate.
See <https://bugs.launchpad.net/gcc-linaro> for instructions.
scripts/Makefile.build:328: recipe for target 'lib/raid6/neon4.o' failed
make[2]: *** [lib/raid6/neon4.o] Error 1
scripts/Makefile.build:587: recipe for target 'lib/raid6' failed
make[1]: *** [lib/raid6] Error 2
Makefile:1034: recipe for target 'lib' failed
Re: lib/raid6/neon4.c:118:1: internal compiler error: in dwarf2out_frame_debug_adjust_cfa, at dwarf2cfi.c:1078
Posted: Tue Jul 10, 2018 9:33 am
by jamesh
What git branch are you on? Should be the 4.14.y one.
Posted: Tue Jul 10, 2018 9:44 am
by siva93krishna
i am in rpi-4.14.y
git branch result
* rpi-4.14.y
issue is with cross compiler.but i followed steps mentioned in below link
But i Enabled DEBUG_INFO
then i am facing that issue .
Please give me the inputs .
Posted: Tue Jul 10, 2018 9:48 am
by jamesh
i am in rpi-4.14.y
git branch result
* rpi-4.14.y
So it compiles cleanly if DEBUG_INFO is not enabled?
Posted: Tue Jul 10, 2018 9:51 am
by siva93krishna
yes . no issues if i am disabling DEBUG_INFO
kernelhacking-> Compile the kernel with debug info
Posted: Tue Jul 10, 2018 10:32 am
by jamesh
Do you use any other non-standard configs that might be affecting the build?
TBH, there not much we can do about this - its an internal compiler error, so would be dealt with by the GCC team, and they have probably already fixed it in more recent versions.
So you could try a different toolchain with a more recent compiler, I believe there are other third party ones out there. Or compile on the Pi itself which I think is a new compiler version, but that will be slower
Posted: Tue Jul 10, 2018 10:37 am
by siva93krishna
Hi Jamesh ,
Thanks for your reply.
can you please provide links for third party toolchain.
Posted: Tue Jul 10, 2018 11:06 am
by jamesh
No, but I expect Google will find something. Or you could probably build the toolchain yourself.
Posted: Sun Jul 29, 2018 9:19 pm
by ppryga
Hi there,
I have had similar problem and fortunately found some solution. In the tools repository there is newer toolchain 4.9.3. Use that and kernel including debug symbols will build successfully. I haven't try to run it on a device yet, but gdb had loaded vmlinux and symbols are there.
Greetings,
Piotr
Posted: Mon Jul 30, 2018 11:26 pm
by asavah
What's your gcc version/toolchain?
https://github.com/raspberrypi/tools/issues/52
On a side note: that ancient crap on the tools repo should be updated to match gcc/binutils version in raspbian.
