Rochadion
Kernel 4.9 firmware failed to get gpio
Mon Oct 02, 2017 11:01 pm
So i just recently build my kernel base on the official site local building and somehow after i reboot i get this error in boot
raspberrypi-firmware soc: firware:Request 0x00030043 returned status 0x80000001
brcmexp-gpio soc : expgpio:failed to get GPIO 0 config (-22)
and this goes on until i goes to GPIO 7 then just starts up. im i supposed to do something about this???
i search though what it meant and i saw this guys post but i dont understand what he meant and how he solved his problem:
viewtopic.php?f=71&t=187794
ShiftPlusOne
Re: Kernel 4.9 firmware failed to get gpio
Tue Oct 03, 2017 10:43 am
If the solution is the same as his, you need to update the actual firmware files. rpi-update is the tool that can do it for you, or you can download the files yourself:
https://github.com/raspberrypi/firmware ... aster/boot
Rochadion
Tue Oct 03, 2017 11:46 am
Well im not entire sure about having the same solution as his, though base on his post the error he gets is same as mine when booting.
about rpi-update, i used that command but it says i already have the newer version but still.
PS: im a complete newbie in raspi and just started, so i dont really understand how to update the and what you mean by downloading it. Sorry :(
Am i supposed to download everything in there and replace the once inside the sd card?
ShiftPlusOne
Tue Oct 03, 2017 12:06 pm
Try this:
sudo rm /boot/.firmware_revision
sudo SKIP_KERNEL=1 rpi-update
sudo reboot
Rochadion
Tue Oct 03, 2017 12:20 pm
The firmware failed messeage is now gone, Thank you very much sir. Really helped :D
ShiftPlusOne
Tue Oct 03, 2017 1:13 pm
No worries, glad it worked.
Return to “Linux Kernel”
