plugwash
Has there been a major change in the firmware and/or dtbs?
Thu Jun 01, 2017 6:09 pm
I'm trying to update the debian-style kernel/firmware packages in raspbian (where we ship kernel and firmware/dtbs seperately) but i'm finding that there seem to be major compatibility issues.
Trying to boot a 4.4 kernel with the new firmware/dtbs hangs at the rainbow screen.
Trying to boot a 4.9 kernel with the old firmware/dtbs appears to start booting but fail to mount the rootfs for some reason.
Has there been a major change in the kernel to firmware interface and/or the dtbs between 4.4 and 4.9 ? Is there any way to make a firmware/dtbs package that works with both kernels?
plugwash
Re: Has there been a major change in the firmware and/or dtb
Thu Jun 01, 2017 7:04 pm
Further testing shows it is the dtbs that are the issue.
PhilE
Fri Jun 02, 2017 8:45 am
Yes, there has been a major change. Between 4.4 and 4.9 we switched to using the upstream bcm2835 board support library, and several other upstream drivers. Although we try to preserve backwards compatibility, avoiding breaking changes between kernel and firmware versions where possible, the expectation is that the dtbs are treated as part of the kernel package.
plugwash
Sat Jun 10, 2017 1:33 pm
Turns out a relatively small change to the dtbs will make both kernels boot. My patch script is at
https://github.com/raspbian-packages/ra ... /fixupdtbs
Gavinmc42
Sun Jun 11, 2017 1:32 am
About time.
This drove me nuts, I have been sticking to 4.4 and not doing update/upgrade for field units.
Updating/Upgrading to 4.9 is for bleeding edge users, sometimes it works, sometimes it harikari's.
Any idea when 4.9 becomes official?
I'm dancing on Rainbows.
runboy93
Sun Jun 11, 2017 9:04 am
Gavinmc42 wrote:About time.
If you have updated your Raspbian, there should be kernel 4.9.24 on your system.
Return to “Linux Kernel”
