alexm
Kernel doesn't start after buildroot rebuild
Thu Sep 13, 2012 4:27 pm
I use buildroot for build kernel and rootfs [https://github.com/nezticle/RaspberryPi-BuildRoot]. I need do same changes for linux kernel. I do make menuconfig in /output/build/linux-custom directory then copy .config to board/raspberrypi/ and then do make for buildroot. The kernel is compiled and image and rootfs are created. I move boot and rootfs tars to SD card and start RPi but only logo appears, kernel not start and aren't any messages on screen. So where I do mistake and how to change kernel's config inside a buildroot?
Thanks,
Alex.
Licaon_Kter
Re: Kernel doesn't start after buildroot rebuild
Fri Sep 14, 2012 1:45 pm
list of files and where you put them? did you run as sudo the tar command?
BFQ+BFS or RT on a RPi? 4'real: https://github.com/licaon-kter/ (source and compiled!)
alexm
Fri Sep 14, 2012 6:35 pm
Licaon_Kter wrote:list of files and where you put them?
Files are the same when I built kernel image and rootfs using linux-3.2-raspberrypi.config. All my actions are same too.
Licaon_Kter wrote:did you run as sudo the tar command?
Yes, sure.
I think the kernel's .config file is wrong but I can't understand why.
Licaon_Kter
Fri Sep 14, 2012 7:26 pm
do attach it
alexm
Fri Sep 14, 2012 8:53 pm
The problem is solved. I should do "make linux-menuconfig" in buildroot root dir instead "make menuconfig" in output/build/linux-custom/.
Thanks,
Alex.
manu.dasari
Wed Oct 03, 2012 11:59 am
I compiled the kernel with the default configs, after transferring the image to SD card and try to reboot
the kernel panicked due to missing init.
So i added the below configs and recompiled the kernel.
1. CONFIG_BLK_DEV_INITRD=y
2. CONFIG_INITRAMFS_SOURCE="../target_fs"
However this time the kernel did not even boot up, just the raspberry logo comes up.
Please advice on how to proceed.
Thanks & Regards,
Manu
Licaon_Kter
Wed Oct 03, 2012 3:27 pm
use a good kernel, from a known good image, like Weezy, log in, run:
zcat /proc/config.gz > config.default
backup it first, then take config.default to your build machine ( or on the same ), put it in your linux kernel tree as .config , run make oldconfig, then edit it as you wish
bushra
Fri May 19, 2017 10:21 am
my new kernel version 4.9.27 v+. https://www.raspberrypi.org/documentati ... uilding.md followed that link but raspberry pi starts with logo but i does not boot. i had changed config.txt file. i am beginner i don't know what's problem. thank u
Return to “Linux Kernel”
Who is online
Users browsing this forum: Yahoo [Bot] and 1 guest
