Skinkie
Which OMX_IMAGE_CODINGTYPE are actually supported?
Tue May 28, 2013 10:37 am
typedef enum OMX_IMAGE_CODINGTYPE {
    OMX_IMAGE_CodingUnused,      /**< Value when format is N/A */
    OMX_IMAGE_CodingAutoDetect,  /**< Auto detection of image format */
    OMX_IMAGE_CodingJPEG,        /**< JPEG/JFIF image format */
    OMX_IMAGE_CodingJPEG2K,      /**< JPEG 2000 image format */
    OMX_IMAGE_CodingEXIF,        /**< EXIF image format */
    OMX_IMAGE_CodingTIFF,        /**< TIFF image format */
    OMX_IMAGE_CodingGIF,         /**< Graphics image format */
    OMX_IMAGE_CodingPNG,         /**< PNG image format */
    OMX_IMAGE_CodingLZW,         /**< LZW image format */
    OMX_IMAGE_CodingBMP,         /**< Windows Bitmap format */
    OMX_IMAGE_CodingKhronosExtensions = 0x6F000000, /**< Reserved region for introducing Khronos Standard Extensions */
    OMX_IMAGE_CodingVendorStartUnused = 0x7F000000, /**< Reserved region for introducing Vendor Extensions */
    OMX_IMAGE_CodingTGA,
    OMX_IMAGE_CodingPPM,
    OMX_IMAGE_CodingMax = 0x7FFFFFFF
} OMX_IMAGE_CODINGTYPE;
I already found in a thread that JPEG2000 is not supported. I have some issues with PNG, could anyone add to the header what is actually supported and what is not?
See also: http://www.raspberrypi.org/phpBB3/viewt ... 87#p358287
TLS
Re: Which OMX_IMAGE_CODINGTYPE are actually supported?
Fri Jun 21, 2019 1:40 pm
The following coding types are not supported:
- OMX_IMAGE_CodingJPEG2K,
- OMX_IMAGE_CodingTIFF
The following coding types are supported:
- OMX_IMAGE_CodingJPEG,
- OMX_IMAGE_CodingGIF,
- OMX_IMAGE_CodingPNG,
- OMX_IMAGE_CodingBMP,
- OMX_IMAGE_CodingPPM
Unfortunately the Broadcom decoder firmware does not understand all coding "dialects" and can crash on some images (i.e. GIF images). It might not be possible to handle the error and/or recover the videocore (decoder) state when such a crash occurs. Very high resolution images can also result in buggy behaviour.
There is an issue with PNG decoding: the decoder only accepts images that have a height that is aligned with 16.
The following coding type is accepted by the image_decode component:
- OMX_IMAGE_TGA
but the decoder crashes on all my TGA test files....
6by9
Fri Jun 21, 2019 4:43 pm
You've commented on a post that is 6 years old!
And you just ask the component for the supported formats via OMX_IndexParamImagePortFormat (or the variant for the relevant domain).
If you have an issue with particular decodes, then please start a new thread, and ideally provide a simple test case.
Return to “OpenMAX”
