dividuum
Dual HEVC decoding
Wed Sep 18, 2019 2:59 pm
I've modified dom's 2711 FFmpeg branch and I'm playing with it trying to decode multiple HEVC streams at the same time. From what I understand, the code should support multiple threads working with the argon (is there an official name for it?) hardware decoder. At least that's what I understand from the usage of thread_idx and the various "thread local variables".
This works decoding a single video when setting the av decoder options 'threads' value to (for example) "auto". I've now refactored the code, so only a single instance of the RPI_DEBUG struct is shared (and ref-counted) across multiple decoder instances, while each decoder has their own pool of zc images. This all works ok when decoding a single video, with or without multiple threads.
When decoding two videos, the following happens and both videos corrupt rather quickly:
I suspect that there's still some shared state that I'm missing in rpi_hevc_start_frame, rpi_hevc_decode_slice or rpi_hevc_end_frame. My naive understanding so far is that those functions either have their state in the respective AVCodecContext, or in the "slotted" variables selected by thread_idx. So multiple invocations for two videos should only refer to either their state in the AVCodecContext or in the thread local state selected during each rpi_hevc_start_frame/rpi_hevc_decode_slice/rpi_hevc_end_frame cycle.
To further prevent state leaking, I've also tried to lock frame decoding to a single user, by acquiring a global lock at the start of rpi_hevc_start_frame and releasing it at the end of rpi_hevc_end_frame. This also doesn't help. Anyone have any suggestion what I might overlook?
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
6by9
Re: Dual HEVC decoding
Thu Sep 19, 2019 1:14 pm
I haven't played with it yet, but I know the person who has been integrating hardware acceleration into VLC and Chromium has.
I've asked him the question of whether he had multiple decodes sorted. I think he had, but had done a couple of fixes. I recall something along the lines of a block of memory being allocated which was sufficient for 3 clients, but something wrong in there.
(edit: correct typo of encodes for decodes to avoid confusion)
dividuum
Thu Sep 19, 2019 2:02 pm
I've asked him the question of whether he had multiple encodes sorted. I think he had, but had done a couple of fixes. I recall something along the lines of a block of memory being allocated which was sufficient for 3 clients, but something wrong in there.
Chromium or VLC already have HEVC support? I took a brief look at the RPi chromium patches (correct me, if I'm looking in the wrong place), but I don't see anything that would hint at HEVC support in there. Multiple old-style MMAL vc.ril.video_decode components for H264 at the same time work fine. It's only the HEVC support in the 2711 branch of FFmpeg where I didn't yet get that to work properly, yet.
Thu Sep 19, 2019 2:15 pm
Both still in testing AIUI, but VLC is pretty close to release.
Return to “OpenMAX”
