dividuum
Playing UHD H264
Mon Jul 01, 2019 9:00 am
How exactly does that work? Can we the existing OpenMAX API? I tried omxplayer with jellyfish-120-mbps-4k-uhd-h264.mkv from http://jell.yfish.us/ without success:
[email protected]:~# ffprobe jellyfish-120-mbps-4k-uhd-h264.mkv
ffprobe version 4.1.3-1+rpt1 Copyright (c) 2007-2019 the FFmpeg developers
[...snip...]
Input #0, matroska,webm, from 'jellyfish-120-mbps-4k-uhd-h264.mkv':
  [...snip...]
  Duration: 00:00:30.03, start: 0.000000, bitrate: 120490 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709, progressive), 3840x2160 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 1k tbn, 59.94 tbc (default)
[email protected]:~# omxplayer jellyfish-120-mbps-4k-uhd-h264.mkv
have a nice day ;)
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
gkreidl
Re: Playing UHD H264
Mon Jul 01, 2019 9:15 am
Edited: The H264 decoder only supports 1920x1080.
Minimal Kiosk Browser (kweb)
dividuum
Mon Jul 01, 2019 9:33 am
Oh. Didn't know that. Thanks. So HVEC is required for that? How does one decode that? I naively modified my existing code to send HVEC video frames to the `video_decode` component and never got a OMX_EventPortSettingsChanged event. Is OMX still supported or is mmal or some other method the recommended way to decode video now?
6by9
Mon Jul 01, 2019 11:26 am
https://www.raspberrypi.org/forums/view ... 3&t=243414
https://github.com/raspberrypi/firmware/issues/1168
FFmpeg is probably the safest bet for now, using V4L2 for decode.
HEVC will be using most likely be using the V4L2 stateless API (current ones are using the stateful API), but FFmpeg should use whichever one is required.
Return to “OpenMAX”
