oomek
Non sequential timestamps causing premature EOS flag
Mon Apr 15, 2019 12:45 pm
As you know after calling av_read_frame() you get AVPacket timestamps not always in the sequential order. This causes premature EOS flag in the fill_egl_texture_buffer callback.
I emit the EOS in the follwing way after sending all the frames to the decoder:
if ((flags & DONE_READING) && (~flags & LAST_BUFFER))
	if ((omx_video_buffer = ilclient_get_input_buffer (video_decode, VIDEO_DECODE_INPUT_PORT, 1)) != NULL)
		omx_video_buffer->nFilledLen = 0;
		omx_video_buffer->nFlags =  OMX_BUFFERFLAG_TIME_UNKNOWN | OMX_BUFFERFLAG_EOS;
		if (OMX_EmptyThisBuffer (ILC_GET_HANDLE (video_decode), omx_video_buffer) != OMX_ErrorNone)
			printf ("error emptying last buffer error\n");
	SET_FLAG(LAST_BUFFER);
ilclient_wait_for_event(egl_render, OMX_EventBufferFlag, 221, 0, 0, 1, ILCLIENT_BUFFER_FLAG_EOS, -1);
The log from decoding thread shows the following timestamps at the end of the stream with 7 second duration:
V: 6790111
V: 6840166
V: 6806800
V: 6823477
V: 6856844
V: 6873533
V: 6906900
V: 6890211
V: 6923577
V: 6956944
V: 6940266
V: 6973633
V: 6990311
But the callback shows flag=17 (EOF+EOS) prematurely at frame with timestamp 6923577 where it should be 6990311
6790111  FLAGS: 16
6806800  FLAGS: 16
6823477  FLAGS: 16
6840166  FLAGS: 16
6856844  FLAGS: 16
6873533  FLAGS: 16
6890211  FLAGS: 16
6906900  FLAGS: 16
6923577  FLAGS: 17
---av_seek_frame 0 ---
6940266  FLAGS: 16
6956944  FLAGS: 16
oomek
Re: Non sequential timestamps causing premature EOS flag
Tue Apr 16, 2019 9:33 am
Strangely this behaviour starts to manifests on the second pass in a looped video. EOS is signalled on the correct frame on the first pass.
oomek
Wed Apr 17, 2019 10:16 am
If you need any further details please let me know as I desperately need to get to the bottom of this.
6by9
Wed Apr 17, 2019 11:04 am
Sorry, I'm out of the office all week.
I'd need a full test case that can be easily built (ie make, cmake, or provided script) to be really digging into it.
I'd suggest that you provide a timestamp (last pts + 1) rather than relying on time unknown flag.
oomek
Sat Apr 20, 2019 1:52 am
There are few issues that I'm struggling with at the moment which I believe are related:
1. On the second and all consecutive video passes 2 last frames are not displayes due to the premature EOS flag
2. With timer preroll = 0ms frames 2&3 and last 2 are not drawn
3. With timer preroll = -200ms 2 last frames are not drawn
Preroll is set in player.c at line 164
Here is a working example with stripped off audio thread that shows the issues I'm having. Please use the test video provided.
https://github.com/oomek/rpi-mediaplayer/tree/no-audio
Usage:
make clean all
./bin/player loop test1.mp4
Pause: space, enter
Stop: s, enter
oomek
Sat Apr 20, 2019 1:59 pm
Hi, freezing was caused by unneccessary usleep in my code, but now frames 2&3 and last 2 are not drawn on the second pass.
I've updated my post above to reflect the current state.
Return to “OpenMAX”
