ktb92677
Remove Video scheduler and Clock elements from hello_pi/hello_video/video.c to improve latency
Mon Apr 01, 2019 10:59 pm
I am writing a h264 stream application involving the raspberry PI as the decoder. I noticed that on 60fps the device had significant decoding latency with just the default code available at hello_pi/hello_video/video.c. I read here: viewtopic.php?t=41584 and here viewtopic.php?f=67&t=235825 that one way to improve latency was to remove the video scheduler and clock components from the code. I did my best to try and remove these elements but I cannot get past this error: "assertion failure:ilclient.c:554:ilclient_disable_tunnel():error == OMX_ErrorNone".
Here's my code:
decoder->port_settings_changed = 0;
  decoder->first_packet          = 1;
  decoder->Buffer = NULL;
  memset(decoder->List,    0, sizeof(decoder->List));
  memset(decoder->Tunnel,  0, sizeof(decoder->Tunnel));
  memset(&decoder->Format, 0, sizeof(OMX_VIDEO_PARAM_PORTFORMATTYPE));
  bcm_host_init();
  decoder->Display = vc_dispmanx_display_open(0); //why is this zero? who knows...
  if (vc_dispmanx_display_get_info(decoder->Display, &decoder->Info)) {
    return;
  decoder->Width  = decoder->Info.width;
  decoder->Height = decoder->Info.height;
  if((decoder->Client = ilclient_init()) == NULL) {
     return;
  if (OMX_Init() != OMX_ErrorNone) {
     ilclient_destroy(decoder->Client);
     return;
  if(ilclient_create_component(decoder->Client, &decoder->Video_Decode, "video_decode", ILCLIENT_CREATE_FLAGS_T(ILCLIENT_DISABLE_ALL_PORTS | ILCLIENT_ENABLE_INPUT_BUFFERS)) != 0) {
    return;
  decoder->List[0] = decoder->Video_Decode;
  if (ilclient_create_component(decoder->Client, &decoder->Video_Render, "video_render", ILCLIENT_DISABLE_ALL_PORTS) != 0) {
    return;
  decoder->List[1] = decoder->Video_Render;
  set_tunnel(decoder->Tunnel,     decoder->Video_Decode,    131, decoder->Video_Render, 10);
  if (ilclient_setup_tunnel(decoder->Tunnel, 0, 0) != 0) {
    return;
  ilclient_change_component_state(decoder->Video_Decode, OMX_StateExecuting);
  decoder->Format.nSize              = sizeof(OMX_VIDEO_PARAM_PORTFORMATTYPE);
  decoder->Format.nVersion.nVersion  = OMX_VERSION;
  decoder->Format.nPortIndex         = 130;
  decoder->Format.eCompressionFormat = OMX_VIDEO_CodingAVC;
  if (OMX_SetParameter(ILC_GET_HANDLE(decoder->Video_Decode), OMX_IndexParamVideoPortFormat, &decoder->Format) == OMX_ErrorNone &&
        ilclient_enable_port_buffers(decoder->Video_Decode, 130, NULL, NULL, NULL) == 0) {
Any help would be greatly appreciated!
6by9
Re: Remove Video scheduler and Clock elements from hello_pi/hello_video/video.c to improve latency
Tue Apr 02, 2019 9:53 am
Please don't duplicate between github and here, otherwise you just waste our time.
https://github.com/raspberrypi/firmware/issues/1127
As per response there
Your code appears to be a significant change from hello_video as things like the function names have changed. Sorry, I'm not going to debug your code.
I've made the required changes to hello_video and pushed them to https://github.com/6by9/userland/tree/fw1127 as a quick hack.
dom
Tue Apr 02, 2019 2:33 pm
Return to “OpenMAX”
