piense
image_decode metadata
Sat Feb 10, 2018 11:14 pm
Does the image_decode component support metadata? I'm trying to enumerate the tree after decoding a jpeg and am just getting a single parent node. It'd be nice to be able to get at least the orientation if it's in the EXIF data.
6by9
Re: image_decode metadata
Sun Feb 11, 2018 7:01 am
Yes, it is supported - I wrote that code about a decade ago!
I'll see if I can dig out the test code for it as the spec isn't terribly clear on exactly what you need to call.
piense
Mon Feb 12, 2018 3:55 am
Haha, always fun when old code comes back to haunt you. The enumeration process seemed simple enough but will all things IL I'm imagining I'm in the wrong state or something. I'm running this function after decoding is complete with EOS on the output buffer but I haven't closed any ports or changed states yet. Here's the doc I'm following:
https://github.com/raspberrypi/firmware ... adata.html
And my demo code:
//use with nodeID OMX_ALL to start, not getting much data from jpegs (?)
void printChildNodes(uint32_t nodeID, OMX_HANDLETYPE handle)
int ret2;
OMX_CONFIG_CONTAINERNODECOUNTTYPE containerCount;
containerCount.nSize = sizeof(OMX_CONFIG_CONTAINERNODECOUNTTYPE);
containerCount.nVersion.nVersion = OMX_VERSION;
containerCount.nParentNodeID = nodeID;
ret2 = OMX_GetConfig(handle,OMX_IndexConfigContainerNodeCount,&containerCount);
if(ret2 != OMX_ErrorNone)
pis_logMessage(PIS_LOGLEVEL_ALL,"JPEG Decoder: meta3: %s\n", OMX_errString(ret2));
printf("Num nodes: %d\n",containerCount.nNumNodes);
OMX_CONFIG_METADATAITEMTYPE metadataItem;
OMX_CONFIG_CONTAINERNODEIDTYPE node;
for(int i = 0;i<containerCount.nNumNodes;i++){
node.nNodeIndex = i;
node.nParentNodeID = nodeID;
node.nSize = sizeof(OMX_CONFIG_CONTAINERNODEIDTYPE);
node.nVersion.nVersion = OMX_VERSION;
ret2 = OMX_GetConfig(handle,OMX_IndexConfigCounterNodeID,&node);
pis_logMessage(PIS_LOGLEVEL_ALL,"JPEG Decoder: meta4: %s\n", OMX_errString(ret2));
printf("Node Name: %s\n",node.cNodeName);
if(node.bIsLeafType == OMX_TRUE){
metadataItem.eScopeMode = OMX_MetadataScopeNodeLevel;
metadataItem.eSearchMode = OMX_MetadataSearchItemByIndex;
metadataItem.nMetadataItemIndex = node.nNodeID;
metadataItem.nSize = sizeof(OMX_CONFIG_METADATAITEMTYPE);
metadataItem.nVersion.nVersion = OMX_VERSION;
ret2 = OMX_GetConfig(handle,OMX_IndexConfigMetadataItem,&metadataItem);
pis_logMessage(PIS_LOGLEVEL_ALL,"JPEG Decoder: meta5: %s\n", OMX_errString(ret2));
printf("Metadata value: %s=%s\n",metadataItem.nKey, metadataItem.nValue);
}else{
printf("Printing children of: %d\n",node.nNodeID);
printChildNodes(node.nNodeID,handle);
Thanks for the help, appreciate any words of advice you might have.
6by9
Mon Feb 12, 2018 10:52 am
Sorry, it's going to take a little time to dig out what is expected for metadata.
My implementation was for the old (deprecated) read_still and write_still components, which did all the file access as well as decode/encode stuff. I'm not sure how that has been carried across to image_decode and image_encode where the handling is based on buffers being passed in.
It'll be IFD0.Orientation that you're after for orientation. IIRC IFD0 vs IFD1 (main image vs thumbnail) was selected by setting the OMX_MetadataScopePortLevel and seelcting the appropriate stream with OMX_IndexParamActiveStream.
Is there any reason you can't use libexif or similar to read the info on the ARM? In the long run it's likely to be almost as quick and a lot less effort.
6by9
Mon Feb 12, 2018 11:01 am
Ah, just noted in the image_decode source that at the same point it sends the EOS it calls a function called id_metadata_cleanup that will nuke the metadata structures.
It looks like you need to interrogate the metadata after sending the first buffer (80kB is guaranteed to include the full EXIF) and before sending the EOS/decoding the last stripe. That latter condition could be tricky on very small JPEGs that fit in < 80kB.
piense
Mon Feb 12, 2018 9:09 pm
Ah, I'll have to play with the buffers and see what I can pull out. The input buffering seems to be a bit finicky though. I may just use that library, mostly I was playing with the idea while I contemplated/procrastinated some other parts of the code. Is the source for the components available somewhere? I don't mind digging out those types of idiosyncrasies myself but best as I can figure those sections are still behind a blob somewhere. Thanks again for the assist.
Return to “OpenMAX”
