DebugAssistant
How to enable vcos log?
Mon Dec 18, 2017 10:19 am
I'm trying to implement "video_decoder -> egl_render" chain in my application. I already have OpenGL SDL crossplatform engine, and need to add EGLImage to use with it.
I'm trying create EGLImage like in hello_videocube:
GLuint textureId;
EGLDisplay display = eglGetDisplay(EGL_DEFAULT_DISPLAY);
glGenTextures(1, &textureId);
glBindTexture(GL_TEXTURE_2D, textureId);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA,
                 1280, 720,
                 0, GL_RGBA, GL_UNSIGNED_BYTE, NULL);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
EGLImageKHR eglImage = eglCreateImageKHR(
            display,
            EGL_NO_CONTEXT,
            EGL_GL_TEXTURE_2D_KHR,
            (EGLClientBuffer)textureId,
            NULL);
But i have got EGL_NO_IMAGE_KHR in eglImage and EGL_BAD_PARAMETER in eglGetError().
I'm trying to switch on vcos_logging and view what wrong in eglCreateImageKHR, but don't know how to do this right.
VCOS_LOG_CAT_T egl_khr_image_client_log = VCOS_LOG_INIT("egl_khr_image_client", VCOS_LOG_INFO);
vcos_log_set_level(&egl_khr_image_client_log, VCOS_LOG_INFO);
How switch on vcos logging for particular VCOS_LOGGING_CATEGORY and how to view it?
6by9
Re: How to enable vcos log?
Fri Dec 22, 2017 12:25 pm
If you're talking about the ARM side logging, then setting
export VC_LOGLEVEL="egl_khr_image_client:trace"
should do the trick.
DebugAssistant
Fri Dec 22, 2017 1:28 pm
And how can i view this log?
I already found mistake.
GLuint textureId;
EGLContext context = eglGetCurrentContext();
                 1280, 720,
            display,
            context,
            NULL);
6by9
Fri Dec 22, 2017 2:23 pm
It'll spit it out to either stdout or stderr (can't remember which off the top of my head).
Return to “OpenMAX”
