Vipe
Hello_videocube play 720p
Thu Aug 24, 2017 1:37 pm
I am playing with the example hello_videocube and for two days I'm trying to play 720p via demuxing (and maybe later 1080p).
The 720p's videos have different data here is the metada with mediainfo :
720test_CBR10.mp4 :
General
Complete name                            : 720test_CBR10.mp4
Format                                   : MPEG-4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/mp41)
File size                                : 149 MiB
Duration                                 : 2 min 13 s
Overall bit rate                         : 9 326 kb/s
Encoded date                             : UTC 2017-08-23 17:09:37
Tagged date                              : UTC 2017-08-23 17:09:44
©TIM                                     : 00:00:00:00
©TSC                                     : 25
©TSZ                                     : 1
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : [email protected]
Format settings, CABAC                   : Yes
Format settings, RefFrames               : 3 frames
Format settings, GOP                     : M=4, N=25
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 9 134 kb/s
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 25.000 FPS
Standard                                 : PAL
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.396
Stream size                              : 146 MiB (98%)
Language                                 : English
Tagged date                              : UTC 2017-08-23 17:09:37
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
720test_CBR3.mp4 :
General
Complete name                            : 720test_CBR3.mp4
Format                                   : MPEG-4
File size                                : 48.8 MiB
Overall bit rate                         : 3 057 kb/s
Encoded date                             : UTC 2017-08-23 17:09:28
Tagged date                              : UTC 2017-08-23 17:09:31
©TIM                                     : 00:00:00:00
©TSC                                     : 25
©TSZ                                     : 1
Video
Format                                   : AVC
Codec ID                                 : avc1
Bit rate                                 : 2 865 kb/s
Height                                   : 720 pixels
Standard                                 : PAL
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.124
Stream size                              : 45.7 MiB (94%)
Language                                 : English
Tagged date                              : UTC 2017-08-23 17:09:28
720test_HighFlowRate :
General
Complete name                            : 720test_HighFlowRate .mp4
Format                                   : MPEG-4
File size                                : 162 MiB
Overall bit rate                         : 10.1 Mb/s
Encoded date                             : UTC 2017-08-23 17:09:30
©TIM                                     : 00:00:00:00
©TSC                                     : 25
©TSZ                                     : 1
Video
Format                                   : AVC
Codec ID                                 : avc1
Bit rate                                 : 9 825 kb/s
Height                                   : 720 pixels
Standard                                 : PAL
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.426
Stream size                              : 157 MiB (97%)
Language                                 : English
Encoded date                             : UTC 2017-08-23 17:09:31
720test_AverageFlowRate :
General
Complete name                            : 720test_AverageFlowRate.mp4
Format                                   : MPEG-4
Codec ID                                 : M4V  (M4V /mp42/isom)
File size                                : 54.9 MiB
Overall bit rate                         : 3 441 kb/s
Encoded date                             : UTC 2017-08-23 17:09:26
©TIM                                     : 00:00:00:00
©TSC                                     : 25
©TSZ                                     : 1
Video
Format                                   : AVC
Format settings, CABAC                   : No
Format settings, RefFrames               : 2 frames
Format settings, GOP                     : M=1, N=25
Codec ID                                 : avc1
Bit rate                                 : 3 250 kb/s
Height                                   : 720 pixels
Standard                                 : PAL
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.141
Stream size                              : 51.9 MiB (94%)
Language                                 : English
Tagged date                              : UTC 2017-08-23 17:09:26
If I use a 720p's video downloaded from Youtube it works but with this videos it doesn't. the video Start with a green screen but on the cube it's black on one video, and on other video it's all green. I don't know at all where is the error ...
here is the code :
void * readVideo(void *argArf){
  int err;
  videoInfo * arg = (videoInfo*) argArf;
  ILCLIENT_T * client;
  if((client = ilclient_init()) == NULL){
    printf("ilclient_init failed\n");
    return (void*)-1;
  if(OMX_Init() != OMX_ErrorNone){
    ilclient_destroy(client);
    printf("omx init failed\n");
    return (void*)-1;
  COMPONENT_T * decodeComponent, * schedulerComponent, * clockComponent;//, * renderComponent;
  decodeComponent = schedulerComponent = clockComponent = NULL;//renderComponent = NULL;
  TUNNEL_T decodeTunnel, schedulerTunnel, clockTunnel;
  eglImage = arg->eglImage;
  if(eglImage == 0){
    printf("eglImage is null.\n");
    exit(1);
  ilclient_set_fill_buffer_done_callback(client, my_fill_buffer_done, 0);
  err = ilclient_create_component(client, &decodeComponent, "video_decode", (ILCLIENT_CREATE_FLAGS_T)(ILCLIENT_DISABLE_ALL_PORTS | ILCLIENT_ENABLE_INPUT_BUFFERS));
  if(err != 0){
    printf("Setup Decode component failed\n");
    return (void*)-1;
  err = ilclient_create_component(client, &renderComponent, "egl_render", (ILCLIENT_CREATE_FLAGS_T)(ILCLIENT_DISABLE_ALL_PORTS /*| ILCLIENT_ENABLE_INPUT_BUFFERS */| ILCLIENT_ENABLE_OUTPUT_BUFFERS));
  if(err != 0){
    printf("Setup Render component failed\n");
    return (void*)-1;
  err = ilclient_create_component(client, &clockComponent, "clock", (ILCLIENT_CREATE_FLAGS_T)ILCLIENT_DISABLE_ALL_PORTS);
  if(err != 0){
    printf("Setup Clock component failed\n");
    return (void*)-1;
  OMX_TIME_CONFIG_ACTIVEREFCLOCKTYPE refClock;
  OMX_INIT_STRUCTURE(refClock);
  refClock.eClock = OMX_TIME_RefClockVideo;
  err = OMX_SetConfig(ilclient_get_handle(clockComponent), OMX_IndexConfigTimeActiveRefClock, &refClock);
  assert(err == OMX_ErrorNone);
  OMX_TIME_CONFIG_SCALETYPE scaleType;
  OMX_INIT_STRUCTURE(scaleType);
  scaleType.xScale =  (-1 << 16) / 1000;//0x00010000;
  err = OMX_SetConfig(ilclient_get_handle(clockComponent), OMX_IndexConfigTimeScale, &scaleType);
  err = ilclient_create_component(client, &schedulerComponent, "video_scheduler", (ILCLIENT_CREATE_FLAGS_T)ILCLIENT_DISABLE_ALL_PORTS);
  if(err == -1){
    printf("Setup Scheduler component failed\n");
    return (void*)-1;
  OMX_VIDEO_PARAM_PORTFORMATTYPE videoPortFormat;
  OMX_INIT_STRUCTURE(videoPortFormat);
  videoPortFormat.nPortIndex = 130;
  err = OMX_GetParameter(ilclient_get_handle(decodeComponent), OMX_IndexParamVideoPortFormat, &videoPortFormat);
  videoPortFormat.nIndex = 0;
  videoPortFormat.eCompressionFormat = OMX_VIDEO_CodingAVC;//OMX_VIDEO_CodingAutoDetect;//
  videoPortFormat.eColorFormat = OMX_COLOR_FormatUnused;
  if(arg->fpsScale > 0 && arg->fpsRate > 0)
    videoPortFormat.xFramerate = (long long)/* (1 << 16) */ arg->fpsRate / arg->fpsScale;
  else
    videoPortFormat.xFramerate = 25 * (1 << 16);
  //  videoPortFormat.xFramerate = 0;
  err = OMX_SetParameter(ilclient_get_handle(decodeComponent), OMX_IndexParamVideoPortFormat, &videoPortFormat);
  OMX_PARAM_PORTDEFINITIONTYPE portParam;
  OMX_INIT_STRUCTURE(portParam);
  portParam.nPortIndex = 130;
  err = OMX_GetParameter(ilclient_get_handle(decodeComponent), OMX_IndexParamPortDefinition, &portParam);
  portParam.format.video.nFrameWidth = arg->widthVideo;
  portParam.format.video.nFrameHeight = arg->heightVideo;
  err = OMX_SetParameter(ilclient_get_handle(decodeComponent), OMX_IndexParamPortDefinition, &portParam);
  /* OMX_CONFIG_BOOLEANTYPE timeStampMode; */
  /* OMX_INIT_STRUCTURE(timeStampMode); */
  /* timeStampMode.bEnabled = OMX_TRUE; */
  /* err = OMX_SetParameter(ilclient_get_handle(decodeComponent), OMX_IndexParamBrcmVideoTimestampFifo, &timeStampMode); */
  /* assert(err == OMX_ErrorNone); */
  OMX_CONFIG_LATENCYTARGETTYPE latence;
  OMX_INIT_STRUCTURE(latence);
  latence.nPortIndex = 221;
  latence.bEnabled = OMX_TRUE;
  latence.nFilter = 10;//2;
  latence.nTarget = 0;//4000;
  latence.nShift = 3;
  latence.nSpeedFactor = 0;//-135;
  latence.nInterFactor = 0;//500;
  latence.nAdjCap = 100;//20;
  err = OMX_SetConfig(ilclient_get_handle(renderComponent), OMX_IndexConfigLatencyTarget, &latence);
  err = ilclient_change_component_state(decodeComponent, OMX_StateIdle);
  if(ilclient_enable_port_buffers(decodeComponent, 130, NULL, NULL, NULL) == 0){
    ilclient_enable_port(decodeComponent, 130);
    OMX_BUFFERHEADERTYPE *omxBuffer;
    ilclient_change_component_state(decodeComponent, OMX_StateExecuting);
    setDecoderConfig(decodeComponent, arg->extradataSize, arg->extradata);
    OMX_TIME_CONFIG_CLOCKSTATETYPE cstate;
    OMX_INIT_STRUCTURE(cstate);
    err = OMX_GetConfig(ilclient_get_handle(clockComponent), OMX_IndexConfigTimeClockState, &cstate);
    cstate.eState = OMX_TIME_ClockStateRunning;//OMX_TIME_ClockStateWaitingForStartTime;
    cstate.nWaitMask = 1;
    err = OMX_SetConfig(ilclient_get_handle(clockComponent), OMX_IndexConfigTimeClockState, &cstate);
    set_tunnel(&decodeTunnel, decodeComponent, 131, schedulerComponent, 10);
    if(ilclient_setup_tunnel(&decodeTunnel, 0, 0) != 0){
      printf("Cannot set clockTunnel\n");
      return (void*)-1;
    set_tunnel(&schedulerTunnel, schedulerComponent, 11, renderComponent, 220);
    if(ilclient_setup_tunnel(&schedulerTunnel, 0, 1000) != 0){
      return (void*)-1;
    set_tunnel(&clockTunnel, clockComponent, 80, schedulerComponent, 12);
    if(ilclient_setup_tunnel(&clockTunnel, 0, 0) != 0){
      return (void*)-1;
    else{
      ilclient_change_component_state(clockComponent, OMX_StateExecuting);
      OMX_SendCommand(ilclient_get_handle(clockComponent), OMX_CommandPortEnable, 80, NULL);
    AVPacket packet;
    while(av_read_frame(arg->context, &packet) >= 0){
      if(packet.stream_index != arg->videoIndex)
  	continue;
      omxBuffer = ilclient_get_input_buffer(decodeComponent, 130, 1);
      if(((packet.size == 0 && ilclient_wait_for_event(decodeComponent, OMX_EventPortSettingsChanged, 131, 0, 0, 1, ILCLIENT_EVENT_ERROR | ILCLIENT_PARAMETER_CHANGED, /*1000*/0) == 0)
	  || (packet.size > 0 && ilclient_remove_event(decodeComponent, OMX_EventPortSettingsChanged, 131, 0, 0, 10000) == 0))){
	  printf("setup decodetunnel failed\n");
	  break;
	ilclient_change_component_state(schedulerComponent, OMX_StateExecuting);
	  printf("setup schedulertunnel failed \n");
	  break;
	ilclient_change_component_state(renderComponent, OMX_StateIdle);
	if (OMX_SendCommand(ilclient_get_handle(renderComponent), OMX_CommandPortEnable, 221, NULL) != OMX_ErrorNone){
	  printf("OMX_CommandPortEnable failed.\n");
	  exit(1);
	if (OMX_UseEGLImage(ilclient_get_handle(renderComponent), &eglBuffer, 221, NULL, eglImage) != OMX_ErrorNone){
	  printf("OMX_UseEGLImage failed.\n");
	  exit(1);
	ilclient_change_component_state(renderComponent, OMX_StateExecuting);
	if(OMX_FillThisBuffer(ilclient_get_handle(renderComponent), eglBuffer) != OMX_ErrorNone){
	  printf("OMX_FillThisBuffer failed.\n");
	  exit(1);
      unsigned int size = packet.size;
      uint8_t* content = packet.data;
      while(size > 0){
	omxBuffer->nFilledLen = (size > omxBuffer->nAllocLen-1) ? omxBuffer->nAllocLen-1 : size;
	memset(omxBuffer->pBuffer, 0x0, omxBuffer->nAllocLen);
	memcpy(omxBuffer->pBuffer, content, omxBuffer->nFilledLen);
	size -= omxBuffer->nFilledLen;
	content += omxBuffer->nFilledLen;
      omxBuffer->nFlags = 0;
      if(size <= 0)
	omxBuffer->nFlags |= OMX_BUFFERFLAG_ENDOFFRAME;
      if(packet.dts == 0)
	omxBuffer->nFlags |= OMX_BUFFERFLAG_STARTTIME;
      else
	omxBuffer->nTimeStamp = ToOMXTime( (uint64_t)(packet.pts * 1000000 / arg->timeBase));
      err = OMX_EmptyThisBuffer(ilclient_get_handle(decodeComponent), omxBuffer);
      if(err != OMX_ErrorNone){
	printf("Empty buffer failed\n");
	return (void*)-1;
      if(size > 0)
  return (void*)1;
thanks for your help.
Kind regard
Vipe
Re: Hello_videocube play 720p
Sat Aug 26, 2017 2:38 pm
Nobody knows? Please at least tell me how to remove the parasites on the videos. I still can not found how to fix it.
6by9
Sat Aug 26, 2017 4:12 pm
Nobody knows?
You haven't given much to go on.
Do the videos play with omxplayer? The codec parameters look OK, but it's hard to say for definite.
Parasites?!
Vipe
Sun Aug 27, 2017 11:37 am
I am sorry if I wasn't very explicit. The videos works very well with omxplayer but see the image for know what happen with my program (that is the parasite, I don't know the real name sorry ) . And this for all videos. Like I said, if I use a 720p's video downloaded from Youtube it works but with this videos it doesn't.
Also, I don't know if it's related, but, on one of these videos, if the xScale from OMX_TIME_CONFIG_SCALETYPE is set to (-1 << 16) the video play normally but on on another it plays very very fast ....
Kind regards
Vipe
Tue Aug 29, 2017 7:30 pm
Please ?
Return to “OpenMAX”
