blackshard83
audio_render time latency
Tue Mar 21, 2017 4:33 pm
Hi all,
I'm not sure if there's already an answer, I could not find any googling around.
Related to my old forum post (viewtopic.php?f=70&t=175450), I would like to know what is the latency, in milliseconds or samples, added by audio_render OMX component?
I see that there is the config option OMX_IndexConfigAudioRenderingLatency that can be queried to get the amount of samples actually queued. I'm guessing who decides the amount of samples queued. Also is there a way to control this value?
blackshard83
Re: audio_render time latency
Wed Mar 22, 2017 4:50 pm
Hmmm, I guess I got it wrong:
my initial thought was that I had to feed the omx component as soon as every buffer is completed, so I have a semaphore which is increased as soon as a buffer is done, catching the EmptyBufferDone callback. This is not ideal because, I realize, the buffer is emptied immediately and transferred into firmware audio_plus library, instead I assumed that the callback would be called after the buffer was effectively played.
Now, taking a look to audio.c progam in hello_pi directory, I realize that there is a usleep to wait to reach the target latency before submitting a new buffer. This approach works pretty well in my code also, but IMO calls to sleep/usleep are naive code.
Any ideas or suggestions? Is there, perhap, a straightforward callback to reach the latency target I want that does the job?
dickon
Wed Mar 22, 2017 6:51 pm
Have you thought about using a clock? If I'm understanding your problem correctly, it would seem to be the right thing to do.
blackshard83
Thu Mar 23, 2017 7:48 am
No, I didn't.
My basic block is a simple audio rendering driver, just a little piece of code that outputs some raw audio.
In my experience, usually you program the audio consumer part (the audio_render component, in this case) with the latency you want (in terms of buffers/samples) and then the consumer asks the data to the producer with the right timing. The timing is intrinsically "hardware" controlled: when a buffer has played, a callback is issued, so you don't need any software timer.
Apparently the audio_render latency can't be set, so unfortunately I can't exploit the timing mechanism
Return to “OpenMAX”
Who is online
Users browsing this forum: No registered users and 2 guests
