snazbaz
venc: enc_open: consistency failed
Fri Feb 17, 2017 7:39 pm
678971.488: venc: enc_open: consistency failed
678971.582: venc: enc_open: other failure
678991.492: venc: enc_open: consistency failed
678991.583: venc: enc_open: other failure
679011.450: venc: enc_open: consistency failed
679011.538: venc: enc_open: other failure
679031.539: venc: enc_open: consistency failed
679031.630: venc: enc_open: other failure
I get these errors after setting up a 'video_encode' component using ilclient and set it to executing.
Does anyone know what it means/what I direction I should be looking in to debug it further?
Thanks!
6by9
Re: venc: enc_open: consistency failed
Fri Feb 17, 2017 9:05 pm
The codec ensures that the resolution and framerate fall within the restrictions imposed by the H264 profile and level specified, and will fail if you exceed them.
Check your encoding parameters against https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels to determine what has been exceeded.
Please don't send PMs asking for support - use the forum.
snazbaz
Fri Feb 17, 2017 9:19 pm
Spot on, that was it! Had the level set too low and didn't notice, thanks!
Return to “OpenMAX”
Who is online
