cmarty
omx_image stops working after latest rpi firmware update
Thu Dec 01, 2016 9:23 am
Hello.
I was happy using example omx_image https://github.com/brynthomas/omx_image for loading jpeg images directly to texture with help of OMX_UseEGLImage.
But after rpi firmware update Commits on Oct4 2016 https://github.com/Hexxeh/rpi-firmware/ ... 6f9bd41e45 it stops working. It stops(stuck) loading image around line 575 in omx_image.c (OMX_UseEGLImage).
I don't know what changed in rpi firmware but I'm not able to modify this example to make it working with the latest rpi firmware update.
bryn
Re: omx_image stops working after latest rpi firmware update
Sat Dec 17, 2016 5:45 am
Think they updated the implementation to be more compliant with the OpenMAX spec.
From the OpenMAX spec https://www.khronos.org/registry/omxil/ ... cation.pdf section 3.1.1.4.5
"The nData2 field of EventHandler specifies the unaltered nFlags field containing the end-of-stream (EOS) flag."
Previously they would just return 0x1 (OMX_BUFFERFLAG_EOS) for the nData2 field even if the nFlags had originally been set to 0x11 (OMX_BUFFERFLAG_EOS | OMX_BUFFERFLAG_ENDOFFRAME). New firmware made it correctly return 0x11.
Changed the code to now work exclusively with the new firmware.
6by9
Sat Dec 17, 2016 12:52 pm
Resize was failing to pass flags or timestamps through correctly (or at all), and that was fixed.
I had had a look at the commit text for the Oct 4th release, but it didn't include details of one of the firmware changes:
resize: Only set the flags on the last stripe and include OMX_BUFFERFLAG_ENDOFFRAME
That included two sections:
+            // only set valid flags on the last frame
+            out->nFlags = output->flags | OMX_BUFFERFLAG_ENDOFFRAME;
-            out->nFlags |= OMX_BUFFERFLAG_EOS;
+            out->nFlags = output->flags | OMX_BUFFERFLAG_EOS;
So that would do it as you are passing in header->nFlags = OMX_BUFFERFLAG_EOS | OMX_BUFFERFLAG_ENDOFFRAME;.
It would have been nice if there had been a link to the issue raised on github to avoid duplicating effort.
Return to “OpenMAX”
