Is it possible to have different framerates for camera and encoder components in ports-tunneling mode?
I need to devide an input framereate by a number. Ex. 30 -> 15 / 10 / 6 / 5. So I just want encoder to omit every second or every third frame. If I set encoder outport framerate parameter to such a value, it fails to record after a while.
P.S. I can't change camera's framerate for my task, because of recording another stream with unchanged fps same time (as described here: http://www.raspberrypi.org/forums/viewt ... 70&t=98197).
