palavrov
Some camera settings doesn't work.
Fri Oct 12, 2018 7:53 am
We hit another problem and need support - @6by9 could you take a look to this please?
Taking two images from the camera with different ISO settings results in more or less the same picture i.e. we were expecting to easily visually differentiate ISO 100 from ISO 200 for example.
Here is a demo project that shows the problem.
https://github.com/palavrov/camera-app
And here are two pictures taken with it:
ISO 100: https://pasteboard.co/HI4OvN5b.jpg
ISO 200: https://pasteboard.co/HI4P2ei.jpg
Changing white balance red/blue gains was not working too, may be it is related?
6by9
Re: Some camera settings doesn't work.
Fri Oct 12, 2018 10:08 am
Trying to tag people using @username does not work on phpBB.
palavrov wrote:Taking two images from the camera with different ISO settings results in more or less the same picture i.e. we were expecting to easily visually differentiate ISO 100 from ISO 200 for example.
Why/how are you expecting to see a difference seeing as you haven't fixed the shutter speed / exposure time. AGC/AE are still aiming for the same target brightness in the scene, therefore your cranking the gain up x2 by setting ISO200 just means it will turn the exposure time down to half the value. No net resulting difference to the images except for possibly some extra noise.
If you were capturing via the stills port the EXIF data would have shown you that. You can read back OMX_IndexConfigCameraSettings to get the current gains and exposure settings.
palavrov wrote:Changing white balance red/blue gains was not working too, may be it is related?
Nope. Almost certainly you haven't set the white balance mode to OMX_WhiteBalControlOff via OMX_IndexConfigCommonWhiteBalance, therefore the automatic algorithm is still running.
Please don't send PMs asking for support - use the forum.
palavrov
Fri Oct 12, 2018 12:43 pm
I think that fixed them i.e. for OMX_IndexConfigCommonExposureValue:
bAutoShutterSpeed is set to OMX_FALSE
nShutterSpeedMsec is set to 50000
bAutoSensitivity is set to OMX_FALSE
nSensitivity is set with the ISO value we want - 100, 200 ...
Isn't that the way to fix them?
Return to “OpenMAX”
