Quote from J Sanderson on November 3, 2011, 21:17
does the 1080p30 mean it can do 1920x1080 only @ 30Hz?
"The GPU is capable of 1Gpixel/s" 1G/(1920x1080)=517 Hz!
Have I got my maths wrong?
What information is available about the SoC itself is at least clear on these issues:
http://www.broadcom.com/products/BCM2835
1080p30 is the quoted limit for H.264 video decoding, whereas 1080p60 is supported for the HDMI output.
The gigapixel/s figure quoted is the fill rate. This needs to be comfortably higher than the output clock rate for 2D work, and considerably higher for 3D.
http://en.wikipedia.org/wiki/Fillrate
Of course, the RaspberryPi team will likely not be able to make all of the capabilities of the SoC available. But I suspect no reason that 60Hz monitor output should be a problem.
