why initWindowSize, why init, and why Start ?
Posted: Sat Apr 16, 2016 8:38 pm
by davenull
hi,
I still haven't got it:
why do I need a
void initWindowSize(int x, int y, unsigned int w, unsigned int h)
. without "&",
what for is
void init(&width, &height)
(and why int hat case with "&"),
and why do I need additionally
void Start(int width, int height)
(and why in that case again without "&" ?)
Re: why initWindowSize, why init, and why Start ?
Posted: Sun Apr 17, 2016 12:08 am
by ajstarks
Note that init and Start were original functions in my OpenVG wrapper.
init() was designed to initialize the low-level graphics environment, and is only meant to be called once, returning the dimensions of the screen. init is to be paired with finish(), which shuts down the graphics environment, again, designed to called once.
Start() is designed to begin a drawing region, conventionally using the dimensions returned in init. It may be called multiple times in your program, and then used with End() to swap buffers and show the picture.
initWindowSize() was introduced later via Paeryn's fork, which introduced more flexible canvas handling.
Posted: Sun Apr 17, 2016 2:34 am
by Paeryn
Continuing on what ajstarks said, the reason why init() takes its parameters preceded by & is because that function passes values back into those values diecrlty. None of he other functions you meantioned have a need to set more than the ongle value allowed by a return..
Posted: Sun Apr 17, 2016 3:08 am
by MarkHaysHarris777
Paeryn wrote:Continuing on what ajstarks said, the reason why init() takes its parameters preceded by & is because that function passes values back into those values diecrlty. None of he other functions you meantioned have a need to set more than the ongle value allowed by a return..
I would add... study what is meant by 'pass by reference,' and 'pass by value'. Some functions return more than the return value (another way of stating Paeryn's case)... and the way they do that is by taking a 'reference' (a pointer) to a data structure (or to an object) and the function then uses that pointer to memory to pass back data into the data structure or object information beyond what is being 'returned' by the function proper :ugeek: .
Do a google search on 'pass by reference' and 'pass by value' as regarding C | C++
Posted: Sun Apr 17, 2016 8:20 am
by davenull
I know of course the difference between pass by value or by reference, that's not the point.
@ajstarks, paeryn:
but initWindowSize has to be called before init, with constant parameters which have to be defined before anyway:
int width=800, height=600;
initWindowSize(100, 100, width, height);
the same then is passed afterwards to init and start:
init(&width, &height));
Start(width, height);
why makes it sense to call this (width, height) 3 times, one after another,
and why has it to be passed by reference to init() which has already been set so far before and which now is not expected to change (or be changed) anything of width, height after that call anyway?
And in which respect is a drawing region different from the screen region?
it's still expected to remain
as defined at the top!
Or what do I miss?
Posted: Sun Apr 17, 2016 12:12 pm
by Paeryn
davenull wrote:@ajstarks, paeryn:
Or what do I miss?
The original init() function just opened a full screen window and returned it's size by filling in the width and height variables pointed to. When I added the ability to choose the size of the window I could have required the user to pass the requested size in via the same width and height, but that could cause problems for existing programs as if the variables hadn't been initialised (quite likely if the were on the stack and there was no need beforehand to set them to any value) then programs could end up having random sized windows. Plus there was no way of specifing an initial position so instead I added the initWindowSize() function that would set internal variables to show a specified size / position was wanted. init() was changed to look at those internal variables and it will reduce the width / height if the requested size was larger than the size of the display. If initWindowSize() isn't called first then init() works exactly as the original. In both cases the actual size of the window created still needs to be passed back as it can be different to what was requested.
Start() takes a width and height (it doesn't have to be the width and height of the screen) as the area to clear (with the origin always at the bottom-left).
What do you mean about the drawing region vs screen region? OpenVG can draw to the whole region of the created window. It can be restricted to a certain rectangle within the window with ClipRect().
Posted: Sun Apr 17, 2016 12:17 pm
by davenull
thank you, now that part is clear to me!
about start:
Do I understand correctly that the coordinates passed to start are just a subset of the whole openVG screen then?
Posted: Sun Apr 17, 2016 12:22 pm
by Paeryn
about start:
The area that Start() clears is a rectangle with it's bottom left corner at the bottom left of the screen and it's top right corner being width,height. So if the screen is 800,600 and you call Start(400,300) then the bottom left quarter of the screen will be cleared, the rest of the screen will retain whatever was already drawn. It doesn't restrict any further drawing to that size, it's purely the size of the area to clear.
Posted: Sun Apr 17, 2016 12:55 pm
by davenull
now that confuses me.
how will be cleared the bottom right quarter instead? or the upper right?
anyway, I actually assumed 4 values to clear a rectangle: x1, y1, x2, y2
and, BTW:
why is start then called "start"? isn't it more a "clear" ?
Posted: Sun Apr 17, 2016 1:17 pm
by Paeryn
and, BTW:
If you want to clear any other area then you need to clear it another way. WindowClear() clears the whole window AreaClear() clears a rectangle (both using the background colour set via a previous Background() or BackgroundRGB() both of which also clear the whole screen whilst setting the colour).
A rectangle does need 4 values, but Start() forces the bottom left to 0,0 and only lets you provide the top-right.
Start() does extra things like changes the background colour to white, clears the lower-left area, sets the fill and stroke colours to black, sets strokewidth to 0 and restores the current transform matrix to identity (i.e. no scale, translate, shear or rotation). I think it intended to be Start of a new frame, i.e. set various parameters back to a default setting. Unfortunately you can't choose what those defaults are.
Posted: Sun Apr 17, 2016 1:29 pm
by davenull
ok, so for clearing the area 100,100 to 200,200 would I also need to call
start(? which values?)
plus
AreaCkear(100,100, 200,200) ?
Posted: Sun Apr 17, 2016 2:01 pm
by Paeryn
davenull wrote:ok, so for clearing the area 100,100 to 200,200 would I also need to call
plus
You only need to use Start() if you want the other things it does as well. If you only want to clear 100,100 to 200,200 and are happy to either change the other settings yourself or want to leave them alone then just use AreaClear(100,100, 101,101); AreaClear's last two parameters are width,height not absolute coordinates and 100->200 inclusive is 101 pixels. I think calling Start(0,0) would not clear any area and just set the other things (I can't remember off hand how it deals with a zero size rect).
Posted: Sun Apr 17, 2016 2:18 pm
by davenull
aaaha. Now the darkness clears up.
Thank you very much! :)
Posted: Sun Apr 17, 2016 2:44 pm
by Paeryn
davenull wrote:aaaha. Now the darkness clears up.
I've just checked, it's an error to pass 0 for either the width or height to Start() or AreaClear().
So at the very minimum Start() has to be Start(1,1) which will clear the bottom-left pixel 0,0.
