Solved - not enough garbage collection.
I'm using 64M GPU memory, so the problem showed up early. I was assuming that memory used during an application would be reclaimed by the O/S, as usually happens with ordinary applications. That isn't the case with the GPU: memory allocated must be explicitly de-allocated or it is still marked as being in use. See the GPU memory use by
/opt/vc/lib /opt/vc/bin/vcdbg reloc
(See e.g.
viewtopic.php?f=70&t=48177). For OpenVG, you need to destroy contexts, surfaces and displays and release threads, as well as destroy paths, images, paints, etc.
The first code below shows GPU memory use with garbage collection (41M free), the second shows it without (33M free)
With explicit garbage collection:
Relocatable heap version 4 found at 0x3b000000
total space allocated is 44M, with 44M relocatable, 0 legacy and 0 offline
0 legacy blocks of size 2359296
free list at 0x3d886760
41M free memory in 2 free block(s)
largest free block is 25M bytes
0x3b000000: free 16M
[2632] 0x3bfc6700: used 576 (refcount 1 lock count 0, size 512, align 4, data 0x3bfc6720, d0rual) 'ILCS VC buffer pool'
[ 718] 0x3bfc6940: used 576 (refcount 1 lock count 0, size 512, align 4, data 0x3bfc6960, d0rual) 'ILCS VC buffer pool'
0x3bfc6b80: free 25M
[ 3] 0x3d886780: used 3.5M (refcount 1 lock count 8, size 3618816, align 4096, data 0x3d887000, d1rual) 'ARM FB'
[ 2] 0x3dbfafa0: used 16K (refcount 1 lock count 0, size 16384, align 32, data 0x3dbfafc0, d0ruAl) 'audioplus_tmp_buf'
[ 1] 0x3dbfefe0: used 4.0K (refcount 1 lock count 0, size 0, align 4096, data 0x3dbff000, d1rual) 'camera fast alloc arena'
small allocs not requested
With no garbage collection:
total space allocated is 44M, with 42M relocatable, 2.3M legacy and 0 offline
1 legacy blocks of size 2359296
free list at 0x3d7858a0
33M free memory in 11 free block(s)
largest free block is 24M bytes
0x3b000000: legacy block 2.3M
0x3b240000: free 1.5M
[2297] 0x3b3c9ca0: used 96K (refcount 1 lock count 0, size 98304, align 256, data 0x3b3c9d00, D1ruAl) 'khrn_hw_bin_mem'
0x3b3e1dc0: free 3.3K
[2124] 0x3b3e2ae0: used 96K (refcount 1 lock count 0, size 98304, align 256, data 0x3b3e2b00, D1ruAl) 'khrn_hw_bin_mem'
0x3b3fac00: free 608
[ 882] 0x3b3fae60: used 96K (refcount 1 lock count 0, size 98304, align 256, data 0x3b3faf00, D1ruAl) 'khrn_hw_bin_mem'
0x3b412f80: free 5.6K
[1040] 0x3b414600: used 96K (refcount 1 lock count 0, size 98304, align 256, data 0x3b414700, D1ruAl) 'khrn_hw_bin_mem'
[2428] 0x3b42c720: used 96K (refcount 1 lock count 0, size 98304, align 256, data 0x3b42c800, D1ruAl) 'khrn_hw_bin_mem'
[ 270] 0x3b444840: used 96K (refcount 1 lock count 0, size 98304, align 256, data 0x3b444900, D1ruAl) 'khrn_hw_bin_mem'
[1765] 0x3b45c960: used 4.0M (refcount 1 lock count 0, size 4194304, align 4096, data 0x3b45d000, d1Rual) 'KHRN_IMAGE_T.storage'
0x3b85d980: free 958K
[2728] 0x3b94d060: used 384 (refcount 3 lock count 0, size 312, align 8, data 0x3b94d080, d1Rual) 'vg_shader_fd'
0x3b94d1e0: free 3.2K
[2036] 0x3b94dec0: used 128 (refcount 2 lock count 0, size 64, align 4, data 0x3b94dee0, D1Rual) 'vg_spath'
0x3b94df40: free 608
[2019] 0x3b94e1a0: used 992 (refcount 2 lock count 0, size 924, align 4, data 0x3b94e1c0, d0rual) 'VG_SERVER_STATE_T'
[ 786] 0x3b94e580: used 2.1K (refcount 1 lock count 0, size 2048, align 4, data 0x3b94e5a0, d0rual) 'KHRN_MAP_T.storage'
0x3b94edc0: free 1.0M
[2290] 0x3ba53cc0: used 568K (refcount 1 lock count 0, size 577696, align 4096, data 0x3ba54000, d1ruAl) 'video_decodeRIL:image pool'
[1059] 0x3bae1d80: used 568K (refcount 1 lock count 0, size 577696, align 4096, data 0x3bae2000, d1ruAl) 'video_decodeRIL:image pool'
[ 592] 0x3bb6fe40: used 568K (refcount 1 lock count 0, size 577696, align 4096, data 0x3bb70000, d1rual) 'video_decodeRIL:image pool'
[1501] 0x3bbfdf00: used 568K (refcount 1 lock count 0, size 577696, align 4096, data 0x3bbfe000, d1rual) 'video_decodeRIL:image pool'
0x3bc8bfc0: free 3.2M
[2632] 0x3bfc6700: used 576 (refcount 1 lock count 1, size 512, align 4, data 0x3bfc6720, d0rual) 'ILCS VC buffer pool'
[ 669] 0x3bfc6940: used 576 (refcount 1 lock count 0, size 512, align 4, data 0x3bfc6960, d0rual) 'ILCS VC buffer pool'
0x3bfc6b80: free 24M
[ 133] 0x3d7858c0: used 64 (refcount 1 lock count 0, size 0, align 32, data 0x3d7858e0, d3ruAl) 'khdispatch_readahead'
[2418] 0x3d785900: used 1.0M (refcount 1 lock count 0, size 1048576, align 32, data 0x3d785920, d3ruAl) 'khdispatch_workspace'
[ 203] 0x3d885940: used 96 (refcount 1 lock count 0, size 22, align 1, data 0x3d885960, d1rual) 'khrn_hw_null_render'
[1507] 0x3d8859a0: used 160 (refcount 1 lock count 0, size 96, align 4, data 0x3d8859c0, d0rual) 'KHRN_MAP_64_T.storage'
[ 698] 0x3d885a40: used 576 (refcount 1 lock count 0, size 512, align 4, data 0x3d885a60, d0rual) 'KHRN_MAP_T.storage'
[ 307] 0x3d885c80: used 1.1K (refcount 1 lock count 0, size 1024, align 4, data 0x3d885ca0, d0rual) 'KHRN_PID_MAP_T.storage'
[1269] 0x3d8860c0: used 576 (refcount 1 lock count 0, size 512, align 4, data 0x3d8860e0, d0rual) 'KHRN_MAP_T.storage'
[ 395] 0x3d886300: used 576 (refcount 1 lock count 0, size 512, align 4, data 0x3d886320, d0rual) 'KHRN_MAP_T.storage'
[ 718] 0x3d886540: used 576 (refcount 1 lock count 0, size 512, align 4, data 0x3d886560, d0rual) 'KHRN_MAP_T.storage'
