dan_in_sd
glxgears from mesa-utils pkg works. but slow
Mon Dec 29, 2014 1:27 am
hello
i have latest raspian image (2014-12-22) and did rpi-update.
I've installed mesa-utils with sudo apt-get install mesa-utils. and then i ran the 'glxgears' command.
i get the rotating gears to show in a window, but performance is slow. 20 fps :(
Q: Can GLX performance be improved on the r-pi?
more GLX info inside my post over in the 'advanced user' forum http://www.raspberrypi.org/forums/viewt ... 4&p=661104
(my apologies for cross posting. sorry )
thanks
RPI #1: Model B | Over-clocked | XBMC | RPI #2: Model B+ 512MB | Beautiful metal case from Lukse.LT | RPI #3: PI2 with Camera, 64GB USB Flash and Wi-Fi
mimi123
Re: glxgears from mesa-utils pkg works. but slow
Mon Dec 29, 2014 8:51 am
You are posting OpenGL info on a GLES forum...
gkreidl
Mon Dec 29, 2014 8:54 am
No, because there is no OpenGL on the Pi.
Minimal Kiosk Browser (kweb)
mimi123
Mon Dec 29, 2014 9:22 am
gkreidl wrote:No, because there is no OpenGL on the Pi.
There is Mesa , see anholt.livejournal.com.
gkreidl
Mon Dec 29, 2014 9:30 am
This is purely experimental and I'm not sure that it will ever be finished (last update October, 2014)
1) you have to compile your own kernel
2) you have to compile your own X-Org
3) You have to compile the drivers
4) It will only "work" with a screen resolution of 1680x1050
If you've done all that, what you get is
Now, you can start the server using startx:
startx -- /home/anholt/prefix/bin/Xorg
This should load the modesetting driver. It won't set up AIGLX successfully, but glamor X acceleration should initialize. Also, it will probably hang pretty soon.
see: http://dri.freedesktop.org/wiki/VC4/
Mon Dec 29, 2014 9:40 am
This mesa stuff is under very active development...not sure of timescales though.
also locking this - use the other thread.
mimi123
Mon Dec 29, 2014 9:47 am
It works on 1360*768 with a one-line patch. And is still very active.
Mon Dec 29, 2014 10:11 am
Mmm, missed the lock button in previous post!
Return to “OpenGLES”
