Im trying to capture the back buffer pixels to a memory buffer for capturing the rendered image.
I have a working code in Windows and im trying to port it to Raspberry Pi.
I do:
GLenum status;
glGenFramebuffers(1, &framebufferID); //i create framebuffer
OGLERROR(__L("glGenFramebuffers")); //check error
glBindFramebuffer(GL_FRAMEBUFFER, framebufferID); //i bind the framebuffer
OGLERROR(__L("glBindFramebuffer"));
glGenRenderbuffers(1, &colorbufferID); //Create and attach a color buffer
OGLERROR(__L("glGenRenderbuffers"));
// We must bind color_rb before we call glRenderbufferStorage
glBindRenderbuffer(GL_RENDERBUFFER, colorbufferID);
OGLERROR(__L("glBindRenderbuffer"));
//The storage format is RGBA8
glRenderbufferStorage(GL_RENDERBUFFER, GL_RGBA, width, height);
OGLERROR(__L("glRenderbufferStorage"));
//Attach color buffer to FBO
glFramebufferRenderbuffer(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_RENDERBUFFER, colorbufferID);
OGLERROR(__L("glFramebufferRenderbuffer"));
glGenRenderbuffers(1, &depthbufferID);
glBindRenderbuffer(GL_RENDERBUFFER, depthbufferID);
glRenderbufferStorage(GL_RENDERBUFFER, GL_DEPTH_COMPONENT16, width, height);
//Attach depth buffer to FBO
glFramebufferRenderbuffer(GL_FRAMEBUFFER, GL_DEPTH_ATTACHMENT, GL_RENDERBUFFER, depthbufferID);
glBindFramebuffer(GL_FRAMEBUFFER,framebufferID);
//Does the GPU support current FBO configuration?
status = glCheckFramebufferStatus(GL_FRAMEBUFFER);
if(status != GL_FRAMEBUFFER_COMPLETE)
switch(status)
case GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT:
XDEBUG_PRINTCOLOR(0,__L("GRPBUFFEROPENGLRENDER::Ini Unable to create Framebuffer : GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"));
break;
case GL_FRAMEBUFFER_INCOMPLETE_MISSING_ATTACHMENT:
XDEBUG_PRINTCOLOR(0,__L("GRPBUFFEROPENGLRENDER::Ini Unable to create Framebuffer : GL_FRAMEBUFFER_INCOMPLETE_MISSING_ATTACHMENT"));
break;
case GL_FRAMEBUFFER_UNSUPPORTED:
XDEBUG_PRINTCOLOR(0,__L("GRPBUFFEROPENGLRENDER::Ini Unable to create Framebuffer : GL_FRAMEBUFFER_UNSUPPORTED"));
break;
default:
XDEBUG_PRINTCOLOR(0,__L("GRPBUFFEROPENGLRENDER::Ini Unable to create Framebuffer : Unknown Reason"));
break;
[...] stripped code here [...]
It returns GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT in Raspberry, but not in Windows.
What I should do?
