PeterO
Fragment shader for waterfall display
Tue May 27, 2014 10:13 pm
The waterfall display in my panadapter currently is in monochrome.
http://www.youtube.com/watch?v=0IZxzm4R1bo
I'm trying to find a "good" algorithm for mapping the 256 values of grey into colours but so far I've had little success,
PeterO
G0DZB
Yggdrasil
Re: Fragment shader for waterfall display
Tue May 27, 2014 10:35 pm
did you mean a mapping like this?
varying vec2 tcoord;
uniform sampler2D tex;
void main(void)
    float val = texture2D(tex,tcoord).x;
    vec3 res = vec3( val*25.0, val*49.0, val*3.0+0.75 );
    res = fract(res);
    gl_FragColor = vec4(res, 0.5) ;
Regards Yggdrasil
PeterO
Wed May 28, 2014 6:46 am
Yggdrasil wrote:Hello,
void main(void)
    res = fract(res);
Regards Yggdrasil
Thanks, but it's not quite what I'm looking for as it doesn't seem to give and sense of the value from the colour. Since the values are "noisy" I end up with a screen of random coloured pixels.
PeterO
Yggdrasil
Wed May 28, 2014 8:12 am
Yes, this shader example uses relativity random colors, but if you reduce the given scaling factors for the r,g,b- values the 'linearity' of the mapping will be increased. It's only necessary to distinct the 1-0 jumps for each the color components. But well, this is the laziest mapping for sure (and still used by me ;) )
Did you have a mapping in mind and just has problems to casting it into a shader?
Or did you just search a good mapping? The second questions has no answer because the quality of the mapping depends one the input data and the 'target information' which should be accent. Well-known is the jet-mapping.
It exists many websites to this topic, i.e. http://cresspahl.blogspot.de/2012/03/ex ... ormap.html ,
PeterO
Wed May 28, 2014 6:32 pm
In the end I took a slightly different approach, and decided to use a RGB texture rather than just a Luminance texture. Now I precompute a 256 entry look up table in the ARM and use it to build a 1024x1 RGB texture to update one line of the the waterfall texture. The fragment shader them becomes the "plain texture shader".
Fro the look up I'm using this code
	bp = wfLut;                    // pointer to start of lookup table
	for(n=0;n<256;n++)
	    nn = (n >> 6) & 3;         // 0..3
	    nnn = (n << 2) & 255;      // 0..252
	    switch(nn)
	    case 0:
		rr = 0;
		gg = nnn;
		bb = (nnn < 16) ? nnn * 16 : 255 ;  // Make lowest values black
		break;
	    case 1:
		rr = 0;
		gg = 255;
		bb = 255 - nnn;
		break;
	    case 2:
		rr = nnn;
		gg = 255;
		bb = 0;
		break;
	    case 3:
		rr = 255;
		gg = 255 - nnn;
		bb = 0;
		break;
	    *bp++ = rr; *bp++ = gg; *bp++ = bb;
Hmmm so much for "code" maintaining layout !
PeterO
drdoug
Mon Dec 29, 2014 10:55 pm
A simple color map that looks nice goes as follows:
Blue: Starts at 0, increases to a max and 1/3 full scale linearly, then decreases linearly to zero at 2/3 full scale
Green: 0 to 1/3 full scale, increases linearly to a max at 2/3 full scale then decreases linearly to 0 at full scale.
Red: 0 to 2/3 full scale, increases linearly to a max at full scale.
PeterO
Tue Dec 30, 2014 7:48 am
You are 7 months too late !
PeterO
Return to “OpenGLES”
