peepo
hello_pi howto build?
Sun Nov 03, 2013 12:36 pm
has anyone built hello_pi recently?
and able to offer advice?
fully up-to-date Rasbian Wheezy
following hello_pi README
sudo make -C libs/ilclient
sudo make -C libs/vgfont
no errors reported
however subsequently there were very many errors when building each program
ie fatal error: interface/vcos/vcos.h: no such file...
I tried editing various files,
interface/vchiq/vchiq.h No such file...
nb vchiq is not present, maybe vchiq_arm?
noted -lpthread is already in makefile.include
cannot seem to find what issue might be?
cheers!
Re: hello_pi howto build?
Sun Nov 03, 2013 2:56 pm
Have you cloned the entire Raspi userland repo, then tried buildme in the root of it?
peepo
Sun Nov 03, 2013 4:30 pm
James,
using /opt/vc/src/hello_pi
perhaps you could elaborate?
It's not clear to me what you are proposing.
thanks again
Sun Nov 03, 2013 7:22 pm
peepo wrote:James,
thanks again
You can git clone the userland source tree that contains all the header files required to build all the example applications.
git clone https://github.com/raspberrypi/userland.git
This will create the tree below the current working directory. Then you should have all the headers you need to build.
Are you compiling on the Raspi or cross compiling? The cross compiler is in
git clone https://github.com/raspberrypi/tools.git
Use the linaro version of the compiler.
peepo
Sun Nov 03, 2013 8:34 pm
James,
/opt/vc/userland/ is present.
apologies but what exactly needs to be done to build hello_pi?
peepo
Mon Nov 04, 2013 10:58 am
have working on another box without userland...
still not clear how to resolve this conflict.
tx
Mon Nov 04, 2013 11:15 am
The buildme script at the root of userland will build all the examples. It'll take a while on a Pi. I've never tried building without userland, so cannot help there.
peepo
Mon Nov 04, 2013 2:09 pm
James,
unfortunately I had tried this, and it did take a few minutes,
however it did not resolve the issue.
iirc there were various error messages similar to those already posted.
hence my persistence...
I wonder if there is something else?
Mon Nov 04, 2013 3:32 pm
Will need the log messages to fathom it out I think.
Emanuele
Thu Nov 07, 2013 1:35 pm
peepo wrote:has anyone built hello_pi recently?
no errors reported
cheers!
Not sure if it's recent enough, but I did build the firmware without building the userland on a minibian (which I guess is close enough to a raspbian) without issues a couple of weeks ago. Actually, I didn't have freetype installed, so I didn't build everything, but most demos were fine.
What about inspecting or copying and pasting the offending gcc line? It should have a -I/opt/vc/include argument somewhere and you should have a /opt/vc/include/interface/vcos/vcos.h in your file system.
Return to “OpenGLES”
