I am newbie to opengles.i tested the hello_triangle program and it works fine.but in this .raw texture were used.
i need to load tga or png texture but it shows error.
can u please help me to solve this.
// Spatial coordinates for the cube
static const GLbyte quadx[1*4*3] = {
-6.626542, -7.047174, -0.000000,
-6.526089, 7.060534, -0.000000,
/** Texture coordinates for the quad. */
static const GLfloat texCoords[1 * 4 * 2] = {
0.f, 0.f,
0.f, 1.f,
1.f, 0.f,
1.f, 1.f,
// A rotating cube rendered with OpenGL|ES. Three images used as textures on the cube faces.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include <assert.h>
#include <unistd.h>
#include "bcm_host.h"
#include "GLES/gl.h"
#include "EGL/egl.h"
#include "EGL/eglext.h"
#include "cube_texture_and_coords.h"
#define PATH "./"
#define IMAGE_SIZE 1024
#ifndef M_PI
#define M_PI 3.141592654
#endif
typedef struct
uint32_t screen_width;
uint32_t screen_height;
// OpenGL|ES objects
EGLDisplay display;
EGLSurface surface;
EGLContext context;
GLuint tex[1];
// model rotation vector and direction
GLfloat rot_angle_x_inc;
GLfloat rot_angle_y_inc;
GLfloat rot_angle_z_inc;
// current model rotation angles
GLfloat rot_angle_x;
GLfloat rot_angle_y;
GLfloat rot_angle_z;
// current distance from camera
GLfloat distance;
GLfloat distance_inc;
// pointers to texture buffers
char *tex_buf1;
} CUBE_STATE_T;
static void init_ogl(CUBE_STATE_T *state);
static void init_model_proj(CUBE_STATE_T *state);
static void reset_model(CUBE_STATE_T *state);
static GLfloat inc_and_wrap_angle(GLfloat angle, GLfloat angle_inc);
static GLfloat inc_and_clip_distance(GLfloat distance, GLfloat distance_inc);
static void redraw_scene(CUBE_STATE_T *state);
static void update_model(CUBE_STATE_T *state);
static void init_textures(CUBE_STATE_T *state);
static void load_tex_images(CUBE_STATE_T *state);
static void exit_func(void);
static volatile int terminate;
static CUBE_STATE_T _state, *state=&_state;
static int i=0;
* Name: init_ogl
* Arguments:
* CUBE_STATE_T *state - holds OGLES model info
* Description: Sets the display, OpenGL|ES context and screen stuff
* Returns: void
int32_t success = 0;
EGLBoolean result;
EGLint num_config;
static EGL_DISPMANX_WINDOW_T nativewindow;
DISPMANX_ELEMENT_HANDLE_T dispman_element;
DISPMANX_DISPLAY_HANDLE_T dispman_display;
DISPMANX_UPDATE_HANDLE_T dispman_update;
VC_RECT_T dst_rect;
VC_RECT_T src_rect;
static const EGLint attribute_list[] =
EGL_RED_SIZE, 8,
EGL_GREEN_SIZE, 8,
EGL_BLUE_SIZE, 8,
EGL_ALPHA_SIZE, 8,
EGL_SURFACE_TYPE, EGL_WINDOW_BIT,
EGL_NONE
EGLConfig config;
// get an EGL display connection
state->display = eglGetDisplay(EGL_DEFAULT_DISPLAY);
assert(state->display!=EGL_NO_DISPLAY);
// initialize the EGL display connection
result = eglInitialize(state->display, NULL, NULL);
assert(EGL_FALSE != result);
// get an appropriate EGL frame buffer configuration
result = eglChooseConfig(state->display, attribute_list, &config, 1, &num_config);
// create an EGL rendering context
state->context = eglCreateContext(state->display, config, EGL_NO_CONTEXT, NULL);
assert(state->context!=EGL_NO_CONTEXT);
// create an EGL window surface
success = graphics_get_display_size(0 /* LCD */, &state->screen_width, &state->screen_height);
assert( success >= 0 );
dst_rect.x = 0;
dst_rect.y = 0;
dst_rect.width = state->screen_width;
dst_rect.height = state->screen_height;
src_rect.x = 0;
src_rect.y = 0;
src_rect.width = state->screen_width << 16;
src_rect.height = state->screen_height << 16;
dispman_display = vc_dispmanx_display_open( 0 /* LCD */);
dispman_update = vc_dispmanx_update_start( 0 );
dispman_element = vc_dispmanx_element_add ( dispman_update, dispman_display,
0/*layer*/, &dst_rect, 0/*src*/,
&src_rect, DISPMANX_PROTECTION_NONE, 0 /*alpha*/, 0/*clamp*/, 0/*transform*/);
nativewindow.element = dispman_element;
nativewindow.width = state->screen_width;
nativewindow.height = state->screen_height;
vc_dispmanx_update_submit_sync( dispman_update );
state->surface = eglCreateWindowSurface( state->display, config, &nativewindow, NULL );
assert(state->surface != EGL_NO_SURFACE);
// connect the context to the surface
result = eglMakeCurrent(state->display, state->surface, state->surface, state->context);
// Set background color and clear buffers
glClearColor(0.15f, 0.25f, 0.35f, 1.0f);
glClear( GL_COLOR_BUFFER_BIT );
glClear( GL_DEPTH_BUFFER_BIT );
glShadeModel(GL_FLAT);
// Enable back face culling.
glEnable(GL_CULL_FACE);
* Name: init_model_proj
* Arguments:
* Description: Sets the OpenGL|ES model to default values
* Returns: void
float nearp = 1.0f;
float farp = 500.0f;
float hht;
float hwd;
glHint( GL_PERSPECTIVE_CORRECTION_HINT, GL_NICEST );
glViewport(0, 0, (GLsizei)state->screen_width, (GLsizei)state->screen_height);
glMatrixMode(GL_PROJECTION);
glLoadIdentity();
hht = nearp * (float)tan(45.0 / 2.0 / 180.0 * M_PI);
hwd = hht * (float)state->screen_width / (float)state->screen_height;
glFrustumf(-hwd, hwd, -hht, hht, nearp, farp);
glEnableClientState( GL_VERTEX_ARRAY );
glVertexPointer( 3, GL_BYTE, 0, quadx );
//glEnableClientState( GL_COLOR_ARRAY );
//glColorPointer(4, GL_FLOAT, 0, colorsf);
reset_model(state);
* Name: reset_model
* Arguments:
* Description: Resets the Model projection and rotation direction
* Returns: void
// reset model position
glMatrixMode(GL_MODELVIEW);
glLoadIdentity();
glTranslatef(0.f, 0.f, -50.f);
// reset model rotation
state->rot_angle_x = 45.f; state->rot_angle_y = 30.f; state->rot_angle_z = 0.f;
state->rot_angle_x_inc = 0.5f; state->rot_angle_y_inc = 0.5f; state->rot_angle_z_inc = 0.f;
state->distance = 40.f;//40
* Name: update_model
* Arguments:
* Description: Updates model projection to current position/rotation
* Returns: void
// update position
state->rot_angle_x = inc_and_wrap_angle(state->rot_angle_x, state->rot_angle_x_inc);
state->rot_angle_y = inc_and_wrap_angle(state->rot_angle_y, state->rot_angle_y_inc);
state->rot_angle_z = inc_and_wrap_angle(state->rot_angle_z, state->rot_angle_z_inc);
state->distance = inc_and_clip_distance(state->distance, state->distance_inc);
glLoadIdentity();
// move camera back to see the cube
glTranslatef(0.f, 0.f, -state->distance);
// Rotate model to new position
//glRotatef(state->rot_angle_x, 1.f, 0.f, 0.f);
//glRotatef(state->rot_angle_y, 0.f, 1.f, 0.f);
//glRotatef(state->rot_angle_z, 0.f, 0.f, 1.f);
* Name: inc_and_wrap_angle
* Arguments:
* GLfloat angle current angle
* GLfloat angle_inc angle increment
* Description: Increments or decrements angle by angle_inc degrees
* Wraps to 0 at 360 deg.
* Returns: new value of angle
angle += angle_inc;
if (angle >= 360.0)
angle -= 360.f;
else if (angle <=0)
angle += 360.f;
return angle;
* Name: inc_and_clip_distance
* Arguments:
* GLfloat distance current distance
* GLfloat distance_inc distance increment
* Description: Increments or decrements distance by distance_inc units
* Clips to range
distance += distance_inc;
if (distance >= 120.0f)
distance = 120.f;
else if (distance <= 40.0f)
distance = 9.5f;
return distance;
* Name: redraw_scene
* Arguments:
* Description: Draws the model and calls eglSwapBuffers
* to render to screen
* Returns: void
// Start with a clear screen
glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
//glEnable(GL_BLEND);
glEnable(GL_TEXTURE_2D);
glTexEnvx(GL_TEXTURE_ENV, GL_TEXTURE_ENV_MODE, GL_REPLACE);
// Draw first (front) face:
// Bind texture surface to current vertices
glBindTexture(GL_TEXTURE_2D, state->tex[0]);
// Need to rotate textures - do this by rotating each cube face
glRotatef(0.f, 0.f, 0.f, 1.f ); // front face normal along z axis
// draw first 4 vertices
glDrawArrays( GL_TRIANGLE_STRIP, 0, 4);
glDisable(GL_TEXTURE_2D);
eglSwapBuffers(state->display, state->surface);
* Name: init_textures
* Arguments:
* Description: Initialise OGL|ES texture surfaces to use image
* buffers
* Returns: void
// load three texture buffers but use them on six OGL|ES texture surfaces
load_tex_images(state);
glGenTextures(1, &state->tex[0]);
// setup first texture
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, IMAGE_SIZE, IMAGE_SIZE, 0,
GL_RGBA, GL_UNSIGNED_BYTE, state->tex_buf1);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, (GLfloat)GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, (GLfloat)GL_NEAREST);
// setup overall texture environment
glTexCoordPointer(1, GL_FLOAT, 0, texCoords);
glEnableClientState(GL_TEXTURE_COORD_ARRAY);
* Name: load_tex_images
* Arguments:
* void
* Description: Loads three raw images to use as textures on faces
* Returns: void
FILE *tex_file1 = NULL;
int bytes_read, image_sz = IMAGE_SIZE*IMAGE_SIZE*3;
state->tex_buf1 = malloc(image_sz);
tex_file1 = fopen(PATH "MyTexture.png", "rb");
if (tex_file1 && state->tex_buf1)
bytes_read=fread(state->tex_buf1, 1, image_sz, tex_file1);
assert(bytes_read == image_sz); // some problem with file?
fclose(tex_file1);
// Function to be passed to atexit().
// clear screen
// Release OpenGL resources
eglMakeCurrent( state->display, EGL_NO_SURFACE, EGL_NO_SURFACE, EGL_NO_CONTEXT );
eglDestroySurface( state->display, state->surface );
eglDestroyContext( state->display, state->context );
eglTerminate( state->display );
// release texture buffers
free(state->tex_buf1);
printf("\ncube closed\n");
} // exit_func()
int main ()
bcm_host_init();
// Clear application state
memset( state, 0, sizeof( *state ) );
// Start OGLES
init_ogl(state);
// Setup the model world
init_model_proj(state);
// initialise the OGLES texture(s)
init_textures(state);
while (!terminate)
//usleep(5*1000);
update_model(state);
redraw_scene(state);
exit_func();
return 0;
