Nagilo
Image Processing with OpenGL and Shaders
Mon Jun 17, 2013 10:55 am
I found this really nice article http://www.linuxjournal.com/content/ima ... nd-shaders but wasn't able to compile it on the rPi. Did anyone ever used this sample?
That's the error I got for make
cc -c -Wformat=2 -Wall -Wswitch-default -Wswitch-enum -Wunused-parameter -Wextra -Wshadow -Wbad-function-cast -Wsign-compare -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wunreachable-code -ffast-math -march=pentium3 -g -DGL_CHECK callbacks.c
cc1: error: bad value (pentium3) for -march switch
make: *** [callbacks.o] Error 1
Re: Image Processing with OpenGL and Shaders
Mon Jun 17, 2013 12:26 pm
The error is pretty self explanatory - you are compiling for a Pentium architecture. The Raspi is an ARM architecture.
rasmus25
Fri Aug 09, 2013 2:43 pm
Also bear in mind that Raspberry Pi does not support the same OpenGL as your desktop computer. Like most embedded systems, it supports OpenGL ES, which is a stripped-down version of OpenGL. You need to modify OpenGL code (including shaders) to make it work on Pi.
Return to “OpenGLES”
