yoth
FIXED: Repeatedly using EGL freezes VideoCore
Fri Mar 22, 2013 2:10 pm
Hi.
I created an application that uses EGL and I wondered why it freezes. Them problem lies with EGL. It can be reproduced with the following code:
int main(int argc, char *argv[])
	EGLDisplay	display_ = EGL_NO_DISPLAY;
	bcm_host_init();
	display_ = eglGetDisplay(EGL_DEFAULT_DISPLAY);
	eglInitialize(display_, NULL, NULL);
	eglTerminate(display_);
	bcm_host_deinit();
	return 0;
I just call eglInitialize and eglTerminate repeatedly. EGL itself works properly but when I start that application around 5 to 100 times it freezes randomly at startup. The process cannot be killed (even with kill -9) and never returns.
Debugging shows that it hangs at:
#0  0xb6d17b5c in ioctl () from /lib/libc.so.6
#1  0xb6f41908 in create_service.constprop.4 () from /usr/lib/libvchiq_arm.so
#2  0xb6f4404c in vchi_service_open () from /usr/lib/libvchiq_arm.so
#3  0xb6f53c84 in vc_vchi_gencmd_init () from /usr/lib/libbcm_host.so
#4  0xb6f5256c in bcm_host_init () from /usr/lib/libbcm_host.so
#5  0x00008660 in main (argc=<optimized out>, argv=<optimized out>) at egl_bug.cpp:17
Any ideas?
yoth
NOTE: Problem was fixed in https://github.com/raspberrypi/firmware/issues/185
pudding
Re: Repeatedly using EGL freezes VideoCore
Mon May 27, 2013 6:01 pm
Yes I'm getting this occasionally. I haven't managed to debug this happening yet. Only way to get around it is to reboot.
Running 2013-02-09-wheezy with default kernel.
Author of MAME4ALL for Pi, PiSNES, PiFBA & PiMenu
pudding
Tue May 28, 2013 1:06 pm
Have you logged an issue on the official Raspberry Pi kernel dev site? They're very good on there at responding to issues.
paddyg
Wed Jun 05, 2013 3:22 pm
Maybe we're (pi3d) having the same issue. We assumed it was a graphics memory leak due our (aka my) slack coding :D
https://groups.google.com/forum/?hl=en- ... 4PkC2bjvcM
I made a new SD card with the 2013-05-25 rasbian yesterday and I can't remember it hanging yet (I wasn't watching out for it) I will post here as soon (or if) it does.
Paddy
also https://groups.google.com/forum/?hl=en-GB&fromgroups=#!forum/pi3d
paddyg
Wed Jun 05, 2013 3:35 pm
I've just created and destroyed a Display (entailing the calls you make in your code snippet) a hundred times and reproduced the freezing so that answers my last point about the raspbian version.
FantasyDR
Sat Jun 08, 2013 11:32 am
Yes, I got the same issue. Application freezed after bcm_host_init() was called.
I could only reboot it...
Jim Manley
Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
Sun Jun 30, 2013 2:27 am
In the unlikely event anyone here interested isn't already plugged into the bugs list, this has been fixed ... and then some!
Requires an apt-get update in order to get the Pi's firmware to a new revision containing the fix.
The best things in life aren't things ... but, a Pi comes pretty darned close! :D
"Education is not the filling of a pail, but the lighting of a fire." -- W.B. Yeats
In theory, theory & practice are the same - in practice, they aren't!!!
paddyg
Fri Jul 05, 2013 11:24 pm
Jim, I found that the apt-get update didn't cut the mustard, it needed rpi-update
yoth
Mon Jul 15, 2013 11:01 am
The problem is fixed in the new firmware.
Return to “OpenGLES”
