MVVadim
eglCreateWindowSurface fails
Wed Mar 20, 2013 7:39 am
Hello everybody,
When I create and destroy my egl client (very much the same as the hello_triangle) in a loop, it fails to initialize after 1024 iterations exactly. All the time, without dependency on resolution of textures it is 1024 iterations. Line where it falls:
eglCreateWindowSurface( display, config, &nativewindow, NULL);
Can anybody help to find out the reason?
I tried to put in the same kind of loop hello_triangle example, but there is the same problem after the same 1024 iterations. So it looks like:
int k=0;
for(k=0; 1; k++){
   bcm_host_init();
   memset(state, 0, sizeof(*state) );
   exit_func();
   bcm_host_deinit();
   printf("%d\n",k);
PeterO
Re: eglCreateWindowSurface fails
Wed Mar 20, 2013 10:09 am
While this could be a memory leak somewhere, or a missing matching "destroy" in your code, I'm curious why you need to call eglCreateWindowSurface than many times ?
PeterO
MVVadim
Wed Mar 20, 2013 10:21 am
PeterO wrote:While this could be a memory leak somewhere, or a missing matching "destroy" in your code, I'm curious why you need to call eglCreateWindowSurface than many times ?
PeterO
Thanks, indeed I can eliminate it, but still I'm curious to know)
Return to “OpenGLES”
