McNopper
OpenGL ES examples with source on the Raspberry Pi
Mon Feb 25, 2013 10:32 pm
I have ported GLUS, a helper library for OpenGL and OpenGL ES to the Raspberry Pi. Also, I have converted 3 of the 21 OpenGL examples to the Raspberrry Pi. Source code from the helper library, the examples and the assets itself are included.
Screenshots: http://nopper.tv/opengles.html
Download: https://github.com/McNopper/OpenGL_ES
How To: https://github.com/McNopper/OpenGL_ES/wiki
The examples do also run on Windows.
Have fun!
Regards Norbert
PS: If I have time, I will convert more examples.
PeterO
Re: OpenGL ES examples with source on the Raspberry Pi
Tue Feb 26, 2013 9:41 am
Interesting, I'll try it out this evening.
But it's yet another library :o ..... Eventually there will be so many libs that people will just have to start writing actual applications :lol:
PeterO
McNopper
Tue Feb 26, 2013 10:50 am
Happy coding :D
PeterO
Tue Feb 26, 2013 7:04 pm
Failed at first hurdle.... It requires Eclipse to build it !
No its worse than that, it requires Eclipse AND a cross complier environment.....
Can't you get eclipse to write out a set of make files so it can be built natively on the Pi ?
PeterO
McNopper
Tue Feb 26, 2013 9:09 pm
At this point of time, I am sorry, I can not create the make files.
For the future, I will create a CMake project. Out of that, make files should be easily created for the target.
Cheers Norbert
PeterO
Tue Feb 26, 2013 9:25 pm
A CMakeLists.txt would be super :-)
PeterO
McNopper
Wed Feb 27, 2013 4:30 pm
For now, the make files are located in the Eclipse build folders of the project. Of course, you would still need to install Eclipse and the cross compiler. But after adaption of these make files, you can build on the target.
Cheers Norbert
McNopper
Mon Mar 04, 2013 6:40 pm
I have added the CMake files. Tested it and now it is possible to build GLUS and the three OpenGL ES 2.0 examples directly on the Pi.
Cheers Norbert
Return to “OpenGLES”
